Truma CP Plus 12v Supply (1 Viewer)
Skipssong
4
Adria Twin Supreme
Hi just joined,
I have a 2020 Twin Supreme 600 SPB.
Does anyone know where the fuse is for the Truma CP Plus 12 supply is? I can't see one related to the CP Plus on the 12v fuse board (under drivers seat). The control panel has gone blank and, on removing it, I can't see 12v on its supply feed. Any ideas?
Oct 10, 2018
1,986
1,123
Bracklesham Bay, West Sussex
PVC
Apart from a supply fuse, which I cant help with but someone with the same van may know, there is a 12v fuse in the electronics beneath the connection cover on the main unit according to my Truma operating instructions (in case the supply fuse when located is found to be ok)
S
Skipssong
4
Adria Twin Supreme
Thanks Geoff, the main 12v fuse board is under the drivers seat but there is no fuse there, that I can see, for the Truma CP Control.
Oct 10, 2018
1,986
1,123
PVC
I have just found that a 10amp fuse marked en route heating (along with other things) is for my controls, this is with a Sargent electrical system but may point you in the right direction with your system.
S
Skipssong
4
Adria Twin Supreme
Hi Geoff, many thanks again. I have located that fuse but it tests ok so I either have a different fault or there's a different fuse elsewhere.
Oct 10, 2018
1,986
1,123
PVC
Is the other 10amp glass 12v fuse, I mentioned, in the electronics panel under the wiring connection cover on the main Truma heater unit ok ? (there is also another 10amp glass 230v fuse in there but in a different position)
S
Skipssong
4
Adria Twin Supreme
Sorted (kinda). Turns out that is a faulty port on the EBL. The power supply to the Truma Control Panel comes off port 20 which is faulty in my 2020 Twin. I've shifted it to a spare port (12) and all is fine. Thanks for the help Geoff
