Truma combi6 e
Skyway
Autotrail
My boiler stop working
No lights at all on panel
And when I look at boiler with cover off I can see a light flashing ?
many help would be great
Brad
Might worthwhile keeping an eye on this thread as well.
Is it the reset button flashing or are you getting a series of long and short flashes? If it's the latter they are giving a code eg, l,l,s,l and if you post that on here somebody will tell you what it means.
Hi it’s light on boiler that’s flashing under the panel you take off
Its
Sslsllls
Its
Sslsllls
Don't have access to the flash code file at the moment but somebody who does will be along in a minute.
faults on combis are usually low voltage low gas or no gas and debris in the flue i would be checking those first
The Truma fault code list states that if the red LED on heater electronics flashes 1 - 8 times it is a heating system fault and to contact Truma service (01283 587900) with the flashing code.
Dont know if you have had any luck yet but I have found that your code could be, along with other things, a bad earth to the combi unit or poor connections at the control panel .
Hello sorry for late reply
Been trying to find someone to repair it today but luckily it’s under warranty and I said they can do it Thursday now we are away on holiday but the campsite it’s got showers we can use and we are passing the motorhome place on the way back on Thursday so it’s ideal I think it could be the air circulation fan for the Comby boiler fan but I’ll have a look at the Earth cables thank you
May be worth also checking the multiplugs are tight on the back of the control panel , the air fan being faulty also comes up with your code, (it is not very helpful when a code points to many possible faults) but glad you have warranty cover so this should sort it out.
Thanks you for you help
