Troubleshooting Nikkai wireless reversing camera (1 Viewer)
Carolmotor
Herts
Van conversion
I have had a Nikkai 2.4ghz wireless reversing camera on my motorhome for 5 years. The picture on the monitor stopped coming on and it displayed nothing more than a blue screen which would then turn off and the blue LED light would flash. Believing it was broken, I purchased a new Nikkai reversing camera which was an exact replacement. I have tried fitting this new one and am faced with the exact same problem of a blue screen which turns off to leave a blue flashing light. Does anyone have any ideas as to what might be wrong? Any help would be much appreciated. Thanks.
11,953
16,570
Sounds like the monitor isn't receiving a signal? Assuming camera has power the receiver in the monitor could be faulty. The best way to find the fault would be to have both devices off the van, near each other, and powered up. With all variables removed if you have the same problem it will be the monitor (or a faulty new camera, or camera and monitor incompatible.]).
2,324
10,061
Not what you are asking, nor probably what you want to hear.. but in my experience, wireless camera systems are a pain at the best of times.. Cut your losses and fit a quality 'hard wired' camera system..
and welcome to fun.. :)
C
Carolmotor
Herts
Van conversion
Thanks for your suggestions, my husband is going to try to sort it out. I'm ready for the moaning and swearing if things don't go right. May end up getting a proper one fitted. :rolleyes:
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
In my experience, nothing with the name Nikkai works very well.
You were lucky to get 5 years out of it, go for a fully wired unit next.
Allan
C
Carolmotor
Herts
Van conversion
All fixed he managed to find a break in a wire between the screen and another part. After taking part of the motorhome to bits to get to it, it's now all fixed. Just hope it lasts.
32,651
66,541
Might be worth getting a spare cheap camera too - we had a similar problem and it ended up being caused by some moisture getting into the camera itself. They are very cheap off Ebay so it pays to have a spare as we found out!
Hymie
810
1,005
Classic Hymer B564
Since 1981
Just had to buy another of these cheap so-called number plate cameras myself.
Took Harriet for a new tyre on Tuesday and there was fogging in the camera, when I got out and looked the clear lens cover has hairline cracks in it and there is condensation inside the lens cover, not sure how old it is.
Would have preferred to fit a better quality camera but whoever fitted the original used 6" nail -sized screws so will fit the new one in the same place to save more empty holes possibly attracting damp.
The original 5mtr cable is still in the cupboard so, with the new 5mtr cable that comes with the camera, I am going to try a solid wired connection this time to try and avoid the occasional break-up of signal the wireless system suffers.
Hymie.
