Hi there, I did try and personal message you as I saw your January thread. Is yours sorted now? Many thanks.I've had 2 replacement airbag ECU's in a Ducato that was new in Jan 2017.
did the thanks mean it worked, because it is a pretty common problem with lots of motors, my renault self build ambulance does it about every 5 times i start it, but a quick tug on the wires cures it.have you tried wriggeling the plug under the seat and unplugging it time or two
No, the thank you meant that's for the tip, but we have already tried everything we can to fix it. Various people have told us all sorts of tricks but none work It's off to the main dealers for a check will will probably mean a new ECU. Thanks thoughdid the thanks mean it worked, because it is a pretty common problem with lots of motors, my renault self build ambulance does it about every 5 times i start it, but a quick tug on the wires cures it.
actually all it means is the airbag wont go off in an accident not that its going to go off at the wrong time.
Of of poHi there, I did try and personal message you as I saw your January thread. Is yours sorted now? Many thanks.
Ours came on like that, first run out after first lockdown, we have solar and battery master. Report was high voltage. ECU too sensitive we thinkTook the mh for it's first ride out in six months on 1st April, airbag fault warning light stayed on. No chance the cause was low battery, as some have reported, as solar and ehu kept the battery's in good nick over winter.
Checked all connections under both cab seats, they seem ok. Connected my cheapo fault finder to the obd2 port, no faults!
Will probably telephone the Liverpool experts on Tuesday after Easter for some advice
Oh dear, SNAP, same set up and same problem!! I also had no faults on my tester! Did you get it sorted?Ours came on like that, first run out after first lockdown, we have solar and battery master. Report was high voltage. ECU too sensitive we think
Yes, I had it repaired by Crash Data, that is where the printed report came from.Oh dear, SNAP, same set up and same problem!! I also had no faults on my tester! Did you get it sorted?
That’s what we thought but that is what the report says. It definitely was not a low battery and came on after a run.14.4v is pretty normal for a battery being charged so 14.6v doesn't seem very high and probably well within measurement tolerance
Just a bit odd that the 14.6v happened a long time and 1500 miles before the ECU was testedThat’s what we thought but that is what the report says. It definitely was not a low battery and came on after a run.
I did use the van all summer whilst researching options, and there was a bit of “putting it off” until the impending MOT in November!Just a bit odd that the 14.6v happened a long time and 1500 miles before the ECU was tested
Hi JezWith apologies if this is a bit of a thread hijack, but, after five relatively trouble-free years owning our 2012 Peugeot Boxer-based Autoquest 180, we have recently joined this unhappy and apparently growing club of airbag ECU fault victims
A similar story to many others... Airbag failure light came on suddenly when starting the motorhome one day before Christmas and remained on, despite attempting to clear it by driving the vehicle and doing a controlled reboot of the main system (e.g. http://www.petercoopercarrepairs.co.uk/peugeot_bsi_reboot_procedure.htm). I enlisted the help of a mobile sparks whose two professional scanners (one £1000 unit and a Snap On unit costing several grand) each of which revealed the dreaded 'B0100-49 Error inside the control unit' code and no others errors.
Sent the airbag ECU off for repair and have now received it back with "before" and "after" reports, which appear to be printouts from the FIat Multiecuscan software. See attached photos - the report with the yellow-highlighted text is the report before they repaired and re-tested the airbag ECU.
There are a couple of things in these reports which I'm not sure about and which I'd appreciate Funsters' advice on, especially from Riverbankannie, Christy, Nigel Crompton and others who have been down this road:
1. The odometer readings recorded against the errors in the reports appears to be many thousands of miles different to my current odometer reading.
The Airbag failure warning and light appeared for the first time ever the week before Christmas (i.e. December 2021), at which point the odometer would have been reading at least 26,202 miles. (I'd successfully MOT'd the van days previously and this was the recorded mileage.)
However, the reports I've received from the repair company give odometer readings of just under 17,000 miles for B0100-49 and the other errors! Based on mileage recorded in previous MOTs and my subsequent usage, my odometer would have last have been at 17,000 miles back in Spring 2019! Has anyone else spotted a similar discrepancy in reports they have received or is it likely that I've possibly received someone else's reports in error?!
2. The post-repair report still shows six other errors:
Have other Funsters also seen similar errors on their post-repair reports? If so, did the faults disappear when you reinstalled the Airbag ECU or did they have to be cleared using a suitable SRS-capable OBD2 tool?
- U1703-07 Communication with Instrument Cluster (IPC/NQS)
- B0106-1B Driver's pretensioner resistance
- B0107-1B Passenger pretensioner resistance
- B0104-1B Passenger airbag resistance (1st stage)
- B0103-1B Driver airbag resistance (1st stage)
- B0127-13 Driver's seat belt switch
Like some others in these forums, I was really surprised to see the root cause attributed to low voltage with the advice to get my battery checked. I replaced the original vehicle battery in January 2020 and fitted a new leisure battery and MPPT solar controller (with logging) last year. I have a Battery Master and am in the habit of checking the voltage of both batteries at least once a month and regularly downloading the logs from the solar controller, with no issues at all.
One possible cause that did occur to me was that I replaced the casing of my nearside wing mirror immediately before the airbag failure appeared. Perhaps unwisely, I did not disconnect the vehicle battery before unplugging and removing the heated mirror glasses, so I guess some sort of short may have occurred - not that the ignition was on at that point. The auto electrician dismissed this as a possible cause of the airbag fault, but I thought I'd just mention it in passing...
I'm obviously going to follow up the above queries with the repair firm, but would appreciate any advice Funsters can give on the above so that I am armed with as much info as possible.
Sorry for the lengthy post but thanks for reading!
Cheers,
Jez
Cheers,
Jez
So, that leads me on to, how do I determine the charging voltage from EHU?I am having similar problems. First was a faulty battery causing low voltage and B0100-49 fault.
Crashdata repaired the ecu. I fitted a new battery, charged it over several days and then fitted the ecu. All good for a few days until I started the van on a cold morning. B0100-49 fault again.
This time, Crashdata say the fault is permanent and a new ecu is required (reconditioned - i.e. old unit reprogrammed to my van!) @ about £360. They believe that the hard start-up was the cause. If so that is a piss poor design from Fiat.
The lady also told me that over the past year, crashdata repairs to airbag ecu's are to a majority of campervans/motorhomes that are just sitting around. She also said that they rarely get any commercial van failures as they are in constant use.
To me that would imply faulty trickle charging of the started battery.
Sure enough, the Shauldt was only charging at 12.8v !
More expence.....
These are very easy to fit and log voltages with cranking test too.. £25So, that leads me on to, how do I determine the charging voltage from EHU?
