Scout
- Apr 4, 2009
- 3,958
- 120,888
- chic c line
- 12 years motorhoming, a lifetime of living
With your setup no. To travel safely with the gas on you need a secumotion regulatior which has crash protection sensor and anti rupture hozes (or cyclinders with built in anti rupture) I see nither in your set up.
AES fridge will select 12v when the engine is running.
The heating may be designed to be used on the move but you still need the relevant safety equipment to use it on the move, i.e. crash sensor regulator and anti rupture hoses. Otherwise you are a danger to yourself and other road users and more importantly if you have a prang the rescue services.We have never switched our gas off. Our Hobby heating system is designed to heat the hab area on the move.
Its up to you, you don't have the 'safety' stuff that they make nowadays as already mentioned, but an AES fridge IMV is meant to be able to select it's own power source all the time without your intervention ... if you don't have the gas turned on obviously it negates the AES function as you'll have to manually switch it to gas when the engine is off (12v will be used whilst driving).
Ok, think about it. Hobby have installed a heating system designed to be used on the move. They have printed a user manual telling you this. If there were any regulations and laws covering this I would imagine they comply (they do, I have checked). I was answering @Scout 's post " is it safe/advisable to travel with the gas on?" that's all @Lenny HBThe heating may be designed to be used on the move but you still need the relevant safety equipment to use it on the move, i.e. crash sensor regulator and anti rupture hoses. Otherwise you are a danger to yourself and other road users and more importantly if you have a prang the rescue services.
Do the new Hyemrs have this? (I'd look but it still at the mender's )With your setup no. To travel safely with the gas on you need a secumotion regulatior which has crash protection sensor and anti rupture hozes (or cyclinders with built in anti rupture) I see nither in your set up.
On the last 2 vans we have had theDo the new Hyemrs have this? (I'd look but it still at the mender's )
So do I.Confession:
We leave our gas on alll the time ...
(Except on the tunnel)
For use when temperature is below 5 deg to reduce the risk of regulator freezing. Never needed to use it in the Exsis we had and unlikly to use it in the DL as the gas locket is in the garage which is heated.( and the heated regulator?).
Did you fit the remote indicator? I find that most important with an auto changeover.Yep, I just wasn't sure if it came as part of the duocontrol option or was another thing you had to ask for.
I've upgraded our std bottle top reg to a Truma CS regulator and a separate Duo changeover - Its then cheaper to just change the regulator if it fails than having to swap the combined regulator/changeover that Hymer fit. I didn't bother adding the heater
We only turn off the gas when refilling our Alugas bottles or on the ferry/tunnel...
Well worth the effort, easy to get the wires through an Exsis.No i didn't fit one as I couldn't find an easy route to feed the wire through to the control panel area in the cab. Also I was suspicious that it wouldn't be very reliable based on my old van which never activated the indicator properly. However this one seems pretty good so maybe I'll fit one as it would be nice to see when it changes over
