odd thing is it has started working but the yellow bulb in the switch is still flashing batteries checked with a meter and confirmed at 12.4 volts ehu not possible at the moment as wild thanksif you batteries are close you could run a temp supply to see if that cures the problem
It's wierd although the manual states yellow light flashing twice ls a low batt fault its working now with the lamp still flashing and meter at 12.3 voltsSwitch off your other 12V stuff, eg, TV, Satellite, most of your lights etc and retry.
Maybe your 12V battery isstruggling.
