Hello I have a 13 pin connection on my tow car and on the moter home it 7 pin
So can I simply put a converter on it will it all work the same lights brakes etc ?
I can get a converter for 5 pounds on flee bay
So I need 7 to 13 converter that’s it
When you say Tow Car, do you mean the Toad that you tow with the Motorhome, or do you mean the car that you tow a trailer ( or caravan) with and you want to tow the same trailer or caravan with your Motorhome?Hello I have a 13 pin connection on my tow car and on the moter home it 7 pin
Then Follow Geo ’s adviceToad
I have a motorhome wired by the same chimp. He's French.Too much advise IMHO is a dangerous thing, unless you are 100% sure what your working with
I have no idea who made the Towing equipment in question or what wiring format they used.
Experience has taught me that they dont always stick to the same given formula.
Known as fitters choice with bespoke installations, he has 13 pins and wires to play with, he has to follow industry standards for the seven lighting / Caravan circuits, that leaves him 6 spare pins and colours to play with and to use for what is required for individual installs of extras.
How many used trailers have folk bought that have been wired by a chimp
Hence my Advice.
Ahh French wiring , now there's a thingI have a motorhome wired by the same chimp. He's French.
The Yanks taught em all they knowAhh French wiring , now there's a thing
May I describe my best (so far) weird wiring? And I've seen many contenders.
Ive read the specs for a specific reason. Pin 12 was originally specified for a trailer present system but the lastest ive read listed 12 as not used. A physical connection was also not included in mine. I use pin 12 as a connection on my toad. It allows a led to illuminate on the towing vehicle.Geo the standard pin configuration is set by EU law. No interpretation for anyone to wire up the extra pins as they choose, with the exception of pin 12 (for now)
Not so simpleO really so I have to have the moterhome change to 13 pin to match ?
So is that simply ?
