you mean outside of the need to replace the tow car registered numberplate with a duplicate of the motorhome! We used to have a 'on tow' numberplate propped up on the parcel shelf on the tow car.When my towcar is hooked on, all the lights and brakes work in parallel with the M/h. Is there any "legal" requirement to have additional signage such as reflective triangles and "Towcar" visible
Hmmm, in my view it would be a towed vehicle - irrelevant if it had been broken down or not it is still being towed therefore unless legislation says otherwise ‘on tow’ is a valid description.View attachment 489542
Triangles are required fitting as above.
I cut an old numberplate revearsed and mounted triangles with stainless fittings.
The whole assembly is clipped to the car numberplate using the stainless clamp attached.
As mentioned earlier do not use an "ON TOW" sign, it relates to a broken down vehicle. more appropriate is "towed" or " towed vehicle "
I use a sign (numberplate) in the front window stating "TOWING".
Humsafer
Over egging the pudding , the purpose of triangular reflectors are to show that it is a towed vehicle , they are illegal to use on a prime mover .Hmmm, in my view it would be a towed vehicle - irrelevant if it had been broken down or not it is still being towed therefore unless legislation says otherwise ‘on tow’ is a valid description.
It is not legally a “vehicle” when being towed in this manner, it is classed as a “trailer” and therefor has to comply with trailer legislation which is different to towing vehicles that have broken down.Hmmm, in my view it would be a towed vehicle - irrelevant if it had been broken down or not it is still being towed therefore unless legislation says otherwise ‘on tow’ is a valid description.
