toilet skylight (1 Viewer)
Apr 28, 2008
157
30
rayleigh, essex.
Can anyone tell me how to clean between the 2 layers of plastic on the toilet skylight on our hymer B524 as it is only possible to get at a small area around the slots in skylight
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Most can be dismantled by unscrewing the four screws from the top, you need to get up to the roof. We do our every couple of years, makes a difference.
Feb 29, 2012
361
225
Reading & Surgeres France.
Hymer 584
Motor homing since 1998.
Hi,
First you need to take the cover off compleatly.4 spire clips on each pivot.
Place it somewhere that won't cause scratching, I do mine on the lawn.Turn it over carefully & tape over the pivot holes. Then fill the upturned window withhot soapy water & allow to soak a while. Then , using along bottle brush you can clean between the 2 layers. A hose around gets rid of most of the rubbish.
Carefully stand iton end to drain & refit.
You may need new clips that are10 mm & can be found on fleebay. I got mine from a guy in Germany,
Barrie.
P M if I can help further.
Feb 22, 2011
9,762
20,117
Newcastle under Lyme
Hymer B544 A Class
Since 2015
So do the two sections not separate ?
Mine are also rather grubby between the two pieces and was wondering how to clean them
Jul 12, 2013
3,865
5,246
The City of Henlow
Adria Supreme
Since 1980
You and almost every other Motorhome owner must wonder, from time to time, who designed a window that becomes brittle and cannot be cleaned. Me thinks Fiamma have a nice little earner. Over the years I have replaced three.
