Toast maker advice
We use a diablo, yummy!
Ah. I see where I went wrong with this. Specifically, to avoid any jocular replies, although I see you have started already, a non- electric hob-top thingy. Thanks Jim, that is probably the one.
You have to re-read every post these days:):rolleyes:
Reactions: DBK
How do you make toast with that? :unsure: :giggle:
We don't have an oven in our new van and use a Bright Spark stove top toaster. It makes much better toast than the grill in the old van! Fits 2 slices and you soon learn to regulate the gas flame and move the bread around to get an even toasting ?.
A frying pan!!
Never tried it with Warby's or similar but toast baguettes , rolls etc cut in half, toast on hot dry frying pan no problem.
Tried one of those... Not a spot on the type with the wire mesh as Jim uses.. And toast is done in about a minute
About a fiver
Dry frying pan here, makes toast just as good if not better than all the gadgets, saves space too.
We don't bother with toast when we're away usually, although occasionally we'll use the grill to toast a cut baguette for breakfast just to avoid throwing it away (and saves other food of course!)
Denise
Denise
Try a dry frying pan, brings the baguette back to life instead of drying it out.
Us too - it works very well & is the best product we've found so far for toasting on a gas hob (y)
Another for the dry frying pan on the gas
