Three way fridge not working (1 Viewer)
Jugar99
3
4
Hymer B644
I just wanted to say a big thank you for some of the constructive comments made with regards to my motorhome fridge failing to stay late after initially starting with no problem. Having done all the usual dismantling and cleaning to know avail, I picked up a tip to repeatedly rotate the selector switch 30 or more times. This is the dial that selects gas, battery, mains electricity, etc. After what must’ve been 60+ clicks of the switch… Hey presto… It is fixed. Absolutely amazing and thanks again! PS I am reliably informed that the thermocouple rarely fails with a fridge unit.
Feb 22, 2011
9,082
17,640
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Glad it's working but I don't understand what repeatedly turning the switch will do.
You may still have a problem ?
Mar 10, 2016
558
618
Scotland
A Class RMB 750HE
Three years and counting, 30 years a tent tower.
The only thing I can think of is that it is cleaning the switch contacts?
Trevor
Good chance that is exactly what it is doing. Its possible that there is some sort of corrosion build up on the contacts when unused for long periods.
Oct 24, 2015
4,516
20,283
Helgas house
hymer e650 battered!!
None
That happens with my left elbow!!
I think I get a calcium build up on the joint, and sometimes I can’t touch my face,, but when I lay bricks or exercise it for a day, it works lovely!! Same principle I reckon!! Lol x
DBK
17,910
47,658
Plympton, Devon
PVC, Murvi Morocco
That's what worked on mine, it does clean the contacts which is needed I believe as the voltage from the thermocouple is tiny.
However, in the end I had to replace the switch, the fault kept returning. I stripped the faulty one down, cleaned everything but it still wouldn't work reliably but replacing it cured the problem.
Tip: Photograph the switch with all cables in place for safety then change over one wire at a time to the new switch. :)
J
Jugar99
3
4
Hymer B644
Thanks for all the comments guys. I think it does clean the contacts somehow but it may be a signal that the switch is failing. I will wait and see.
Oct 13, 2016
1,027
897
Grays - Essex - UK
Mercedes Hymer B680
Been moho’ing for a time now
I had a similar problem in Germany last year, and it was the switch, but just dirty contacts, so I carefully stripped the switch apart, cleaned it with brake cleaner, then a quick spray WD 40, reassembled then removed the thermostat end of the thermocouple and cleaned the contacts there, but only with brake cleaner, it now works perfectly
Aug 6, 2013
11,834
16,216
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Buy contact cleaner - the stuff that's actually called Contact Cleaner. Don't dismantle the switch just thoroughly hose ever possible entry point with the stuff. Dry it off then refit. It will not fail again and the switch doesn't wear - the contacts develop very minor corrosion through lack of work.
