My fridge is not cooling. I can hear the gas clicking to ignite, the dial moves up to green, and with the temp dial on highest, it just doesn't cool. I've tried the mains and battery settings, even overnight, but still nothing. Any ideas?
Hi Spriddler - Yes, I bought it from motorhomedepot.com just recent (Auto-Sleeper Windrush) - I do have an incline on my driveway which is greater than 3 degrees, but I parked it flat over Easter but still not cooling!I guess from your Profile that the m/h is new to you, so has the fridge ever worked for you?
O.K. but the point of my post was querying whether it has ever worked for you.Hi Spriddler - Yes, I bought it from motorhomedepot.com just recent (Auto-Sleeper Windrush) - I do have an incline on my driveway which is greater than 3 degrees, but I parked it flat over Easter but still not cooling!
Many thanks indeed, very helpful - I'll give all that a goThe fridge works by creating heat to drive the refridgerant around, the heat can be created by gas flame or an electric element either 240v or 12v.
At the top rear of the fridge you will be able to feel the warmth from this heat.
Remove the top rear vent cover and you will see a series of fins around a horizontal pipe. Are they warm or hot.
If on 240v the element could be faulty.
If on gas the jet could be blocked or the flue sooted up.
I would try on mains first. If you can feel heat the element will be ok. It will take a while to produce heat on those fins.
If the fins are hot and the internal freezer plate fins do not get cold then its an issue with the refridgerant or possibly the paste on rear of the freezer fins has dried out.
If fridge works on any heat source the refridgerant circuit is ok.
Hope this might help.
that'll be never then.. since I got it a few weeks agoO.K. but the point of my post was querying whether it has ever worked for you.
A quick word, then, with Motorhome Depot seems to be in order - though as they only act as agents for the sellers I don't think you'll get very far.that'll be never then.. since I got it a few weeks ago
Hi Mike, it most probably was installed when the van was put together by AutoSleeper in 2012How old is the fridge, or least ways the van it's in?
Mike
