Thetford N175 cleaning pcb
Phileas Fogg
west of the tamar
c class
Hi all
Common fault I know but have cleaned the burner and adjusted on our Thetford N175 and still not lighting on gas. Before I spend out on a new motherboard would like toc lean the old one in case it makes a difference... have no idea how to do it though! Any advice greatly appreciated. Thanks
Does the circuit board look rusty ???
We had a similar problem - got the box off then removed the circuit boards dried them thoroughly when I reassembled the box I made sure the box had drainage holes that was 2.5 years ago not had a problem since
which is great considering the cost of a new circuit board
I had same problem and found moving the spark electrode a midges cured it .
Thanks for that and the quick reply, to be honest I haven't even tried to open it as I wanted to make sure I was doing the right thing, assume the cover just unscrews or unclips and you go from there... and it will be the box with all the wires going to it:giggle:
Thanks I have done that, cleaned the electrode and adjusted its position but it has made no difference, tried both gas bottles just in case, have a brand new leisure battery and there is a good spark so it isn't that.
