Thetford N145 no longer working on 12V (1 Viewer)
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
Hi all,
My fridge has just stopped working on 12V, still works fine on 240V and Gas.
All was working well for a 5 hour drive yesterday, but today the LED on the panel indicating battery is flashing once a second. Vehicle battery is fully charged and I have checked voltage (with engine running is at circa 14v at the back of the fridge). Initially I thought it may have been a fuse, so I checked every one I could find in the vehicle and all are ok. But this morning I switched the fridge on and SES automatically selected battery, however it only ran for a couple of hours before flagging up a fault again.
The fridge does not have an LCD so I am not sure what the flashing LED indicates as a fault.
This intermittent fault at least tells me it is not a fuse, any tips/suggestions?
Does it sound like a loose connection or perhaps a circuit board on its way out?
Thanks.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Agree with above answer, fit new element. Cost around £30.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
Great, thanks guys - I will get one ordered :).
Another quick question, where exactly on the back of the fridge is this located and is it likely to be changeable in situ via access through the external vents as opposed to removing the whole unit?
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
Did some investigation, looks like I am taking the fridge out - looks straight forward enough.
Disconnect power/gas/12V/240V cables etc., remove internal fridge screw covers, remove screws and slide fridge out. The following video should prove helpful.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I replaced one on an earlier motorhome through the bottom vent with the fridge in situ. Depends on fridge model and size of vent.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
Well I had to remove the fridge :-(. The DC heater element is out now. Job next weekend is to fit the new one, test, refit fridge and reseal.
Some pics of the fridge and circuit board - Fridge is a Thetford N145A
IMG-20180811-WA0003.jpg 20180811_131339.jpg 20180811_131352.jpg 20180811_131455.jpg 20180811_131503.jpg 20180811_131538.jpg
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
Damn it, changed DC heater element, same issue :cry:.
Posted a video of the LED's on the panel, hopefully someone can tell me what they mean?
(Yes, vehicle engine is running and DC voltage to fridge is at Alternator voltage)
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
What happens if you manually select 12v instead of AES?
Though I must admit it's looking like a circuit board fault.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
Same issue mate, LED goes solid green for a few seconds and then starts flashing, then the RED warning LED starts flashing.
Yeah, I now suspect the circuit board too. Was worth changing the £30 part though before changing a £150 circuit board. Oh well at least the new circuit board will be the newer model :)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Before changing anything else ensure that the 12v supply to the element is still 12v under load. You said the supply to the element was OK originally so assuming nothing has changed if the supply is still there, at the element, the fridge will work. For it not to work either the supply isn't there or the element is faulty.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
I assume by element you are referring to the DC heating element? - if so then we can probably rule the element out as the fridge is showing the same fault with the new one fitted, so your thought is that this could still be a voltage supply issue as opposed to the circuit board? If so I will stick the multimeter on the DC heater terminals of the circuit board while I get someone to switch the fridge on with the engine running.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
I thought from what you said at first that you had checked for 12v at the heater and that it was OK. Which is why, quite reasonably, you believed the element had failed. Having changed the element it should therefore work. It doesn't so that leaves the 12v supply. A 'problem' with multimeters is that they'll read a voltage through a piece of wet string (or a corroded connection or fuse) whereas a decent load, like a bulb or an element, will see nothing. If, however, the circuit board does prove to be faulty take a look at it before buying a new one. Water can run down the wires that enter from the top which might have caused repairable corrosion. Seal that area once you have the fridge working again.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
I measured the voltage at the DC heater terminals today, got a helper to switch the fridge on to DC while I had the multimeter connected, with the engine running I was reading 13.6V at the DC heater element terminals, I could hear a relay click, click again and the fridge presented the previous error.
Tried switching the fridge on and off a few times and it eventually started working on DC (albeit for 5 minutes) before erroring again. Voltage dropped to 12.5V whilst fridge was running. I think this is looking more like a power board issue?, I could be wrong so if anyone has a suggestion - please let me know.
The power board on this fridge is the V1 and I can't find a spare for sale anywhere. I don't want to spend £1800+ on a fridge to fix a problem running on 12V!!! :cry:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Sign of the times innit.
Try offering 13V knowing if push comes to shove you can go to 14.1V
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Got our parts from leisure shop direct.
Found them very helpful when ours packed up (gas faulty)the day we were going away. They let us collect the part from them.
https://www.leisureshopdirect.com/c...thetford-smart-energy-selection-model-fridges
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
That's the new power board unfortunately, they no longer sell the original one I have :-(
I know, when we got ours it was the modified one with a new box, instructions etc. I still have the old one & all the instructions s etc. If it helps I'll dig it out tomorrow.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
If you don't mind, that would be great - I was not sure the new board is interchangeable with the old one - I have had a look online and some of the plug sockets are totally different on the new board.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
No problem, it'll be afternoon when I get up off nights.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
If your fridge is an AES (automatic) , like mine, then the part no. of the new board I fitted is 634422 but this appears to have changed again to 691137. See below.
http://www.thecaravanspecialists.co...etford-popular-parts/thetford-pcb-power-board
Hope this helps, but if not, please feel free to ask.
Feb 16, 2013
19,731
52,008
uttoxeter
ambulance conversion
50 years
Hi all,
Thanks.
dont know what your fridge is like but if you are thinking of changing it for a new one , i would seriously have a look at compressor fridges, no dearer than what you are quoteing and far better.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
Thanks DP_JAY, yes my fridge has AES. I had a look at the 691137 in our local caravan shop and the main connector on the power board is smaller with more pins than the V1 board I have. So if they are compatible with my fridge then it is not just a drop in replacement, unless there is an adapter available (like car stereo adapter leads).
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
If I have to replace the fridge then if I can get a model of compressor fridge the same dimensions as my N145A, then this would be my option of choice :)
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
I would speak to the companies that I linked to, they should be aware & know the answer.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
As a matter of interest do you have the part no. of the pcb in your fridge now?
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
On the first page of this thread, I have posted some pictures of my control board - there are some numbers on the right of the PCB, but I am not sure if these relate to the model No.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Can't see it o n there. It's very small print at the bottom of the cover . Part no.626908 on our original one.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
This is every serial No./part No. I can find on the fridge. The picture with a part No. and Solenoid Gas valve is the cover for my power board.
20180827_145355.jpg 20180827_145404.jpg 20180827_145526.jpg 20180827_145706.jpg 20180827_145801.jpg 20180827_150550.jpg
I just spoke to an engineer that recons the newer boards are not interchangeable with this fridge and there is no wiring harness adapter :-(. And it is easier finding hens teeth than getting one of these older boards.
So it looks like I have two options 1. find someone that can repair the board 2. cry and buy a new fridge. I'll try option 1 first :)
