Thetford Fridge N3000 problems (1 Viewer)
Cooldude
29
16
Midlands
Our 4 year old (out of warranty) Thetford Fridge (N3000) in our AS Broadway has suddenly developed a dim look to the LED touch screen. At the moment the fridge still works, it is just difficult to see the symbols on the screen. The dim images are also shimmering a bit!
Has anyone had a similar problem and if so, how was it sorted? - perhaps a new expensive LCD display and pcb is require? Could be over £200 including fitting!
Any thoughts
Pete
Jan 19, 2014
9,389
24,763
Derbyshire
Elddis Accordo 105
since 2014
Have you tried isolating the power for 5 minutes, works with most gadgets these days. (n)
Cooldude
Cooldude
29
16
Midlands
If you mean switching it off for a while and then switching it back on again, then yes tried that, but still no difference. I originally thought it needed the six AA batteries replacing, so I removed the battery case under the display and lo and behold no batteries and no contacts, it’s a dummy set up!
Thanks for your suggestion.
Pete
