Yes, exactly. Therefore since the panel is no help (is the panel working?) you need to check the basics. As it's not working in any mode you need to use a test meter to check whether power is getting to the fridge control module and the 240v element, but only if you feel comfortable/competent dealing with mains voltage.It's new to me I have checked the manual for the fault codes it's not showing any faults I have also turned it upside down for 5 mins to no avail.
What make of fridge is it? I can’t take mine out without an awful lot of work let alone turn it upside down surly to do that you have to disconnect gas etc? Is this a wind up?It's new to me I have checked the manual for the fault codes it's not showing any faults I have also turned it upside down for 5 mins to no avail.
