Thetford C260 help! (1 Viewer)
Nov 25, 2013
1,119
1,760
kent
Swift Kontiki 669
Since April 2013
Does anyone know how the above is mounted to the MH floor ? I believe we have a leak on the fresh water flush supply possibly the clip on the bowel spout. This model is fed from the main fresh water tank .
Jul 13, 2008
3,738
3,851
Low profile
Might just need to remove the seat from inside the cassette area, not an easy job.
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Hi remove cassette and it will more than likely be screwed to the floor ....uncouple wires and you should be able to remove the whole loo to work on
OldAgeTravellers
1,207
1,387
Telford, UK
Since 1970
Predictive text really does produce some good ones, almost as if they planned it that way. Hope you get it sorted.
Steve
Jul 29, 2013
9,069
18,487
Salisbury
Hymer B678DL A class
since 2011
Are you sure it’s not just a leak around the cassette seal?
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Is the OP saying that the flush outlet in the bowl is dribbling and filling up the bowl?
I've had this problem. Cause was grit in the electronic operated valve located just below the upper surface of the toilet - accessible from the top of the toilet. I used compressed air to clear the grit/debris from the inside of the valve.
