Thetford C250 won't flush (1 Viewer)
TheDentons
284
172
South Wales
swift kontiki
I'm a newbie bought our first motorhome 7months ago and love it
Last week our thetford C250 toilet stopped flushing
I've put a multimeter on it and have 12v at the switch. Trying to decifer if it's the switch or there's another small circuit board that tells you when the cassette is full.
Does this disable the flush when tank is full?
So I can try an isolate the problem.
Is it the switch or tank censor
Cheers
23,836
72,460
No mate.. the cassette full LED is nowt more than that... it is switched by a float arm with a magnet on it inside the cassette..
It can really only be the switch or the solenoid ..
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
It is probably the circuit board behind the press switch has been pushed out of its mounting clips ..... simple to fix by pulling off the switch facia and pressing the board back into the clips.
Good luck and hope you will soon be flushed with success.
TheDentons
TheDentons
284
172
South Wales
swift kontiki
Ordered new push switch and reed switch fitted both still nothing the reed switch looks different and the full light is permanently on have 12v to the button but doesn't flush when pressed
dabhand
4,307
23,935
Staffs
Concorde carver E35
Since 1993
Each time you scratch your ear, pray that it's wax:)
Nov 6, 2013
1,416
3,167
S. Ayrshire
The usual
Since the beginning
Check voltage to the pump when flush button is pressed.
Or
Apply a known good 12v source straight to the flush pump terminals.
Dec 12, 2010
5,409
21,557
Cumbria
Maybe your pump has siezed or stuck ? Can you get at it to give it a gentle tap or at it's terminals to try connecting it direct to 12 volts ?
TheDentons
TheDentons
284
172
South Wales
swift kontiki
Taken pump out runs fine independently I'm baffled
Nov 6, 2013
1,416
3,167
S. Ayrshire
The usual
Since the beginning
This service document shows how to change the pump. Appreciate you've checked the pump, ok. But - have you checked the fuse ?
Nov 6, 2013
1,416
3,167
S. Ayrshire
The usual
Since the beginning
If it's the same housing / type that was used on our old Thetford 402(?), it wasn't easy to see.
A 3A small blade fuse if memory serves me correct
TheDentons
TheDentons
284
172
South Wales
swift kontiki
Fuse is fine I have power to the switch, the only thing that I can think of is that it's the wrong reed switch stopping the toilet flush
An earlier post says the reed switch doesn't effect the flush
Does anybody know this for certain
Cheers
23,836
72,460
Not according to the installation information it doesn't, but it is possible to modify anything I suppose.. Not sure a reed switch ( unless a big one ! ) would have enough contact area to handle the switching current of a pump or solenoid.
It does depend if the reed switch is N O or N C ( Normally Open or Normally Closed ) but...
Simple checks
If it needs to be open then just disconnect one of the feed wires to it and try the flush ( This seems very unlikely though )
Just use a clip lead across the reed shorting it out and see if the flush works.
Dec 12, 2010
5,409
21,557
Cumbria
How old is the toilet ? The reason I ask is in our old Adria caravan a few years back, the toilet stopped flushing and after a lot of searching, I found that the copper wires in the supply cable to the toilet had gone black, a common problem on DC supplied appliances. Anyhoo, I could get 12 volts on my digital multimeter at the bog but not enough current down the wire to run the toilet. Had to run a new supply cable to sort it out :(
