Thetford C223-CS not flushing (1 Viewer)
Graham of Madrid
366
174
Mc Louis Glamys 40
Since 2019
Hello !
My new 1 year-old MH has an intermittent flushing problem. The cassette toilet uses the motorhome pressured water system for flushing. The pump is working because all the taps are working fine with the on-board water tank full.
I'm not sure where to go from here, I suppose it could be a switch problem ?
Any help appreciated !
Dec 6, 2011
12,197
27,279
South Wales
Coach built Adria
as its intermittent it could well be the pressure pad switch, i'd have a look at the connections on the back if you are able.
Graham of Madrid
Graham of Madrid
366
174
Mc Louis Glamys 40
Since 2019
It's solved it was ............... USER ERROR.......
The Thetford has it's own small low pressure pump which goes through the Accessory button on the Control Panel. I thought it was fed from the main pump so I had the Taps button on the Control Panel on. I guess the pressure on the main pump is too great for the flush.
I've a lot to learn.
Thanks for the suggestions.
