canopus
Anyone got thermal panels, ie for hot water, fitted on their property. Interested in any pros, cons.
I havent but I do have a roof full of very discrete PV's. My system is different because it was built from the start around electric and solarAnyone got thermal panels, ie for hot water, fitted on their property. Interested in any pros, cons.
Exactly the same system as us, and also same time 8 years.We've got 16 PV panels, fitted 8 years ago, and have found them very cost effective, we have a solar I-boost which detects excess solar & heats the hot water. We have not used our immersion heater since having solar fitted. Should break even on the original outlay in another 3 years on the feedback tariff we've received, and our electric usage is less, especially when used when you're generating
Paul you have to consider the environment it’s not all about cost! Or so Greta would sayWe have a twin coil cylinder as required a new cylinder anyway and there wasn’t much price difference.
Applied a year ago for the green homes grant scheme for solar thermal, they have p1ssed us around so much with delays, no contact, wrong paperwork they said, further quote, installer not registered they said(Which we proved he was)
Then a few weeks ago they finally said your voucher is waiting to be issued you will hear and get it in about 1 week.
Lovely we thought
2 days later the scheme got scrapped, what a total utter complete joke. They couldn’t run a good drink up in a brewery to coin that phrase without swearing.
Mess em around for over a year and then scrap it as the voucher is about to be issued, you couldn’t make it chuffing up.
Can’t get in touch with them now.
I wouldn’t pay it myself though 5 grand quote to save about £60 a year you would have to be ill to pay yourself about 85 years to break even
Yes the government green homes joke, sorry I mean grant.Paul you have to consider the environment it’s not all about cost! Or so Greta would say
Also a grant says nothing about how good the system the system is, I assume it was a government grant
Works for me - She never fails to get me to turn the TV off and save the energy I would have wasted watching herPaul you have to consider the environment it’s not all about cost! Or so Greta would say
Ours is a Viessmann system they have a national coverage of engineers, but I’m sure if you contact your local plumbing supplier they will tell you of someone local.Our roof has limited sunlight - we have one thermal solar panel - installed 8 years ago. Works really well- we rarely have the water heater on in summer or autumn but despite a concerted effort ( written to solar panel manufacturers/ surfed net thoroughly/ phoned evert solar panel installer I could) we can’t get anyone to service it. It has pipes of pink heat exchange liquid running to the cylinder and these developed a slight leak, we were given a container of the liquid to top up/ replace it if needed and asking our central heating boiler company to do this 3 years ago we were astonished to learn the system seems to be unfathomable an un serviceable.
Thank you but no help there. Only possible lead I had was one company in London who won’t travel this far ...builders fitted ours when we were having extensive work done with help from someone qualified ( apparently!) hot water cylinder is one make but the pipes/ panel another and we never had the paperwork from the builders ... think ours is a Heathrobinson systemOurs is a Viessmann system they have a national coverage of engineers, but I’m sure if you contact your local plumbing supplier they will tell you of someone local.
Hard to imagine you once owned an Autotrail Steve,We had ours changed at ten years the whole system is copper brass and stainless, ours has a collector on the roof like a manifold and the end of the copper rods (in glass tubes) has a bulb shape that is a slide fit into the manifold a bit like a heat exchanger, the fluid is in the heat exchanger and circulates through the coil in the cylinder around 7ltrs per minute from memory.
I was talking to the guy who services our gas boilers and he was telling me that their company have just started replacing all of the air source heat pumps on a 6 year old housing estate due to upgrade 6 YEARS OLD seems to me there is more carbon foot print making these carbon nuetral devices or basically companies making a lot of money from talking b********sWorcester Bosch now make a solar thermal system, as do quite a few others manufacturers. Just wonder if they get government incentives to flog the 'green' carbon neutral stuff.
There are four pairs of council owned, 60's built semi bungalows just down the road from us. The council have just a month ago ripped all the antiquated electric heaters out, and refitted with Air Source heat pump, new cylinder and radiatiors. Talking to one old chap and he says they've never been as warm.
Meeeeeooooowww!Hard to imagine you once owned an Autotrail Steve,
Are you on a bore hole water system Steve? That set up with the vacuum tank looks very similar to ours?
