The drivers side front side light problem
Fiat Ducato
Hi all am new to this forum.
I have a problem with my Fiat Ducato muljet 130 (2013 motorhome) that I need help with. The drivers side front side light (inside the head lamp) comes on very dim and for only 2-3 seconds then goes off. The passenger side is working ok.
Has anyone seen this problem before. If so I would really like to hear how to fix it.
If you check the wiring and any earth connections near the light and all is ok I think you will find that the Right hand front side light is actuated from the Body control module and the connection for this light actuation it is on the fuse box / BCM (inside cab) in the lower right 52x pin multiplug which would be worth checking is fully pressed home..
It could also be a faulty bulb / or contacts that the BCM is sensing and shutting connection down.
Hi Thanx for the reply. Can I ask what is the BCM .... is that the fuse box. If not is it next to the fuse box.
Few a few coppers stick a new bulb in. I think that's the problem .
If that isn't the fault at least you have a spare bulb.
I have already done what you have said in the chat apart from checking the 52x pin multiplug. I have now looked on the net and understand the connections to the fuse box / BCM. Thank you for time.
