Terrible unusable Fiat Ducato speedo design (1 Viewer)
tkk
Jun 9, 2014
357
274
notts
Frankia i640
newbie but learning fast
While Moho in for service I had the Fiat garage carry out the free fix so that dials etc are now permanently illuminated noticed the difference on the 50 mile run home, time will tell.
Hi,
sorry, late into thread. Have recently bought 2019 Frankia, Fiat based KPH dial, terrible visibility of speedo dial at night, hardly seems illuminated atall. What was the fix?
Ta
Tk
Jul 1, 2010
3,198
33,425
SW Northumberland
Hymer B 588 DL
Since September 2010
The Fiat garage will alter the instrument clustered light so it is on permanently when engine is running instead of only when headlights are switched on, its a free fix taking minutes apparently. It makes a little difference but not in bright conditions.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
The upgrade is free because that's what it's worth.
It makes little difference.
GPW
606
878
Cambridge UK
Globescout Plus
Slight to minor!
I notice a lot of Fiat/Peugeot/Citroen coachbuilt drivers seem to sit very high up, very noticeable when they are driving towards you and you can’t see the tops of their heads.
I noticed this in adjustable height seats. They sell it as a feature but I found even on the lowest setting it still added enough height to be incredibly annoying, especially if you have remis blinds as the top cover robs another inch of visible screen height. No use driving to nice places if you can't look 'up' at all!!
So ironically the cheaper 'swivel only' and fixed seats were much more usable for me.
Deneb
1,598
2,334
Europe
PVC
Should be default behaviour on a 2018/19 chassis. It was introduced into production shortly after being made available as an update on older vans.
@tkk have you tried adjusting the illumination level? There should be eight levels available, either through the mode button menu or the radio menu depending on the type of radio fitted. Some settings are only available with ignition on and engine off, and vice versa.
tkk
Jun 9, 2014
357
274
notts
Frankia i640
Ta, Ill try that, didn’t find it on brief play with mode before but will look again, its an alpine sat/nav/radio so probably not thro that.
tkk
Jun 9, 2014
357
274
notts
Frankia i640
Steve N Tracy
1,234
3,727
Southampton
4 Years
I purchased one of these
Its not heads up but displays the speed in mph or kmh, can display 2 other items at the same time, temp, rpm, battery, and can also display and delete fault coded it simply plugs into the odb port using a flat cable.
Mar 8, 2016
725
1,577
Lancashire
PVC
Since 2009
I purchased one of these http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=273551150439
Looking for something to give a big read out like this. Does this have to be plugged into the OBD port or is there a way of funning it off the 12V or USB socket near the dash. Thanks
Steve N Tracy
1,234
3,727
Southampton
4 Years
It has to be plugged i to the odb port to have access to the speed signal on the Canbus its not gps so works in tunnels.
Two on Tour
10,317
50,868
Elddis Autoquest 175
Since 2010
If you have an old Andriod smartphone your no longer using then there are dozens of speedo apps on the Google play store for free. They are GPS but if your driving in a tunnel the you will have dash light on the van speedo cluster to see your speed.
Jul 1, 2010
3,198
33,425
SW Northumberland
Hymer B 588 DL
As others have m entioned if you have an old smart phone there are many free gps app s, its gps so no sim and no data use. Nice large bright numerals easy to read.
Mar 8, 2016
725
1,577
Lancashire
PVC
Since 2009
I think that’s the route we will take. Just asked the younger members of family if they have an old one they don’t use. Had a quick look on Amazon etc. Quite well priced for basic phone. Certainly cheaper than buying a stand alone GPS. Presume as long as phone has GPS it will work.
Two on Tour
10,317
50,868
Since 2010
Jul 1, 2010
3,198
33,425
SW Northumberland
Hymer B 588 DL
Tried various apps on a smart phone all have limitations so bought dedicated unit that plugs into the obd2 port, does all sorts but mph and kph are all that interest me. Nice large bright display easily seen even in the brightest sunlight with the quickest glance. Used for a year now and well pleased.
<Broken link removed>
Jul 5, 2016
492
864
Essex
Burstner IXEO I728G
Ex tugger
If you have a pioneer head unit you can use this in the navigation options
Apr 14, 2020
79
116
County Durham
Timberland Destiny
Since 1995
<Broken link removed>View attachment 514033
I had a look for my OBD port as I was thinking of using it but there appears to be something plugged into it I cannot identify, if I was to take a guess I'm wondering if the conversion company has used it to power something like the rear view camera or the vehicle alarm?
Jul 1, 2010
3,198
33,425
SW Northumberland
Hymer B 588 DL
That’s a strange one the port is essentially for diagnostics I was lead to believe. It’s not a blank by any chance 🤔🤔🤔
SD j
169
289
Adria Twin supreme
Since 2000
My Alarm has a plug into OBD port ,
It’s to stop the thefts using eBay bought obd machines I think
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Lay a mirror onto the steering column. You can see my one. It changes night to day. This is just by reflection from the windscreen.
No lights.
Apr 3, 2019
1,497
2,754
UK
Burstner Travel Van
Few years now
Or change the dials
Tombola
4,815
15,697
Merseyside
Rapido 8094DF
Since 2004
virtually given up with the 2017 Fiat speedo which reads about 5mph high at a true 70mph!!!
I noticed this too on my 2017, my sat nav speed was approx 5mph out, no wonder I thought all those lorrys limited to 56 were doing 60+ :rolleyes:
Abacist
3,726
10,649
Devon
N & B Arto 88F Tag
since 2013
What a great thread - never ever thought about using my phone as a speedometer and speed limiter!
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Is the diabolical dash still being fitted? I hope not.
Although you can overcome the problem yourself (Fiat seem unable) it should never have happened and Fiat should have provided the required solution. If anything is "not fit for purpose", that dash must be one of the main contenders.
