SandraL
- Jan 24, 2012
- 1,373
- 985
- Hymer b694sl
- Since 2012 + Caravanner for 20+ years
Battery life is shortened if battery is at a higher temp. So this nice weather is shortening the life of our batteries.
The optimum operating temperature for the lead-acid battery is 25°C (77°F). As a guideline, every 8°C (15°F) rise in temperature will cut the battery life in half.
Temperature effects on sealed lead acid batteries and charging ...
We have a votronic solar controller with temp sensor mounted on the leisure battery.
In this warm weather it has reduced the float voltage from 13.8 v to 13.5v
which will help to keep temp down.
See .
https://www.votronic.de/index.php/e...rograms-characteristic-lines?showall=&start=1
We rarely use mains power, .but if we did our mains charger has no compensation for high temp, so battery life will be shorter than if we just use the solar with compensation. For me answer is to disc onnect mains from charger and rely on solar in these temps.
Any thoughts?
See .
Any thoughts?
