ThanksAs the others have said, blocked condensate tube or pump issue.
Least likely is low refrigerant charge causing localised ice build up on the evaporator.
If it’s cooling ok, more likely just tube/pump issue.
ThanksRoof mounted ac units have a pump to lift the condensation and discharge it onto the roof of the van (at least mine does) I had a problem in France the pump stuck. I borrowed a ladder from the site I was on and freed it off. If you do be sure to shut off all the electricity if the unit works through an inverter just switching off the 240 won't be enough
Too far from meTamarit in Catalonia
Thanks they keep telling me it’s a sealed unit and cannot in its lifetime be recharged! I’m sceptical! However a blocked condensate drain sounds the most likely cause. It getting onto the roof is not likely on this tour. I’m not as sprightly as I once was!Thanks
