Emmit
The story has nothing to do with Motorhomes, PCV's RV's and the like BUT it does involve a diesel engine fitted with an EGR and that would probably account for a lot of those on Fun.
About five weeks ago, we were travelling home from the IOW to Cornwall in our VW Passat.
We had just got onto the M5 at Exeter when a 'new' to us warning light came on. It was a Red Thermometer in the middle of the Temp Gauge. (Low Water level apparently)
The Temp gauge however was showing a temp within range so, thinking it was a rebel light, I made the decision to keep going on the Motorway until I turned off onto the A30 some 5 miles away.
I pulled up BUT KEPT THE ENGINE RUNNING (REMEMBER THAT BIT) lifted the bonnet and discovered the expansion tank was low on water, hence the red light.
I 'borrowed' SWMBO's drinking water and carried on. There was no sign of any leaks or any steam.
Shortly before Launceston the Thermometer came on again. I limped into Tesco's@ Launceston and filled the expansion tank again and filled the water bottle.Again, I KEPT THE ENGINE RUNNING. Again, there was no steam or signs of leakage.
I arrived home 10miles later and on this occasion, having got home, I switched off and unloaded the car. MISTAKE!!! Big time.
When I tried to restart the car, there was a sort of noise that you get on a cold morning with either a duff starter or weak Battery. A Clunk!. It wouldn't start despite repeated attempts.
The following morning however and after a few 'funny' noises the car started and I drove it the 400yds to 'my' garage.
On arrival and on keeping it going, the car was emitting white 'smoke' from the exhaust.
My man started doing a good impression of a plumber faced with an old boiler and said, Leave it with me.
For various reasons I was only able to collect the car yesterday.
This is what had happened and why I'm posting it here.
The EGR (Exhaust Gas Recirculation which for those non Techies, recirculates hot exhaust gases back into the engine) is cooled by water. The cooler in our car developed a leak which went into the EGR and on into the engine.
WHILE THE ENGINE WAS RUNNING- NO PROBLEM. The water turned into steam as it hit the moving parts and was 'burned' off as the diesel was injected.
However. When I switched the motor off the water continued into the engine courtesy of the pressure in the system and, when I tried to restart, instead of just diesel in the bores, the engine had to contend with water which everyone knows (NO they don't ) cannot compress, and the car objected in the strongest terms possible.
It has been said to me since that just having water in the bores can result in a bent crankshaft, bent con rods, holes in pistons. In short a FUBARed piece of machinery.
Ladies and Gentlemen. This is the result. The cylinder head was removed and sent to a specialist repairer and, thank Him upstairs, it needed just one valve replacing. No Con Rods etc. No holes in Pistons, nothing. However, it did need a new EGR and Cooler, A New Cambelt kit complete with Water Pump (Safety First) and a whole lot of labour.
How much? Think about £2000 and I know I have got away with Murder. A replacement Passat 170bhp engine is North of £4000 plus VAT and that wouldn't include any of the above stuff I've had to replace.
The Moral of this story. If you are losing water but the temp gauge says OK and you can't see any leakage, remember this diatribe.
KEEP THAT ENGINE RUNNING!!! AND DON'T TRY TO RESTART IT UNLESS YOU'VE HAD THE MISSING WATER CHECKED OUT BY AN EXPERT.
