T11 battery terminal
Spain
Hymer B514
6 months in a 10m Southwind in the USA (2014). Just bought a Hymer and embarking on a tour of Spain
Hi,
I’m looking for a battery terminal connector thingie, type T11 I believe (20mm) so I can add stuff to my new battery.
I’ve installed my new LiFeP04 battery, the first step in my system upgrade on my Hymer. Plenty of time for planning while it’s sat outside waiting for the tour to start... some day.
The battery terminal is 20mm with an M 8. Although I’ve managed to connect up the existing stuff, I need to add two more for the new panels and it’s a tight squeeze. The terminals on the old AGM batteries are too small.
I don’t know what they’re called and have struggled to find anything online other than that it’s probably called T11. Can anyone help? Photo attached.
Also I’m considering a single live cable across to the house fuse box, which should probably be 25mm says the panel supplier. I presume I need some sort of specialist connector rather than a normal blade? (2nd photo). I managed to get hold of a few of large ones for the existing cable (which I think is 10mm) but it was a struggle to get the wires in, and I think I need something a bit bigger even for the 10mm wire so what do I use for a 25mm wire? (Presuming I’m able to run such a large wire across the motorhome).
Not that I can see... just smaller clamps. But thank you, maybe I’m looking for a clamp.
I use these...
12V 3Way Battery Terminals Copper Positive Negative Connectors Clamps
It looks perfect BUT I still can’t see a 20mm one, the standard car battery is smaller
If I understand correctly, the terminal is M 8, and the 20mm refers to the size of the hexagon (I can't see if that's point to point or flat to flat on the diagram). M 8 means the thread is 8mm diameter. So you are looking for crimp terminals that have an 8mm hole..
The 'yellow insulated crimp terminals' can be found with an 8mm hole, but the maximum wire size is 6mm2. For larger wires you need uninsulated crimp terminals, sometimes called 'copper tube' terminals.
Uninsulated crimp terminals have two numbers in their description: the hole size and the cable size in mm2. It's easy to mix the two up, so be careful. For example
As Lenny HB says, slide a bit of heatshrink sleeving onto the cable before you crimp. Then slide it back over the joint and over the crimped part of the terminal, and heat with a heat gun, hair dryer etc to shrink it.
Note that heat shrink size is diameter, so for example a 25mm2 cable would be about 10mm diameter including the plastic insulation.
Thanks for a very detailed reply!
My battery terminals are 20mm diameter cylinders with an mate bolt to hold on the connections. I need to fit a few more connections on and there isn’t really room on the mate. That’s why I’m after a 20mm clamp onto the cylinder of the terminal so I can fix more stuff. The old batteries came with one but they are standard car battery size so I’m looking for larger.
In fact i managed to book into an electrical specialist workshop Monday, helping with a leak draining the system, so I’m sure he’ll sort it out. I do like to learn as I go along though.
My opinion is that even if you found a 20mm clamp, it won't do what you want. The proper way to do this is to have a single wire to a busbar, and then you can easily connect extra wires to the busbar.
Usually the wire from the battery goes to a big fuse located very near the battery. From there the wire goes to a busbar, and all the other wires connect to the busbar. Often an isolator switch is fitted between the fuse and the busbar, but that's for convenience, not essential. Ideally the fuse and busbar should be located less than 500mm from the battery.
Edit: I just worked out what a 'mate bolt' is. If you write M 8 without the space, the spellchecker
automatically converts it to 'mate':banghead: :clap:
Brilliant this looks like what I need. I only need to fit a single 25mm cable into the busbar from the battery, then all cables from the regulators from the solar panels plus the BMI and inverter plus a single 25mm cable to the Hymer regulator. Thanks, I shall take a look.
Not sure I understand what your after, but Car builder solutions is normally a good bet
Ooooh!! Pure porn. :hot: That catalogue should have an 'X' rating.
So many things I never knew existed, never mind all those things I never knew I needed!
Now all I need is a project. I suppose a proper workshop might be useful too.
And time.
And space.
Oh, and I suppose a few thousand spare might help.
Oh well, a chap can dream. ☹
