Surflo pumps
laurieash
Scunthorpe
Autotrail Apache
July 2013
Taken my pump apart as there was a small leak from the electrical end and it's rotted one of the live terminals.
Have not found any gasgits between the parts.
Can you just buy the plastic bit. With the spade connection?
As the pump works fine.when you can get a connection.
Plenty of spares for them but not cheap.
When reassembling I smear food grade silicone grease on the matting surfaces also make sure you put thread locking compound (removable type) on the screws that hold the pump to the motor.
and given the cost of spares with potential further future problems you kinda got to ask yourself if it's worth just getting a new "sealed unit"?
Look at the link I posted they have an offer on a lot of the spares at the moment £10 off the bit that the OP needs so could be worth repairing.
Looking at it i just need the micro switch part? but did not know how the water has got in ? maybe from the body and run down to the lowest part which is were the live wires go in.
my plan was to use it as a spare as i replaced it with new straight away as i was away when it packed up.
sorry guys i should have said my intentions.
Just had a look mine only has 3 screws that hold the bottom on.
I have a spare pump I could sell for £20 plus postage
Square at bottom
Be back later boss calling me in for lunch 😸
Thats only part of the assembly.
