andy63
Had a pump to take to bits and have a look at..
Fairly common in a lot of motorhomes ..its the 20 psi model so ill post a few pictures in case its of interest to anyone..
They are posotive displacement pumps and can self prime against a small lift i believe..
The pump body is located on the motor with 3 machine screws..
The motor drives an excentrically mounted bearing which drives 3 plastic pads on a flexible diaphram.. in an elliptical fashion in the pump casing...
Removing another 3 self tapper type screws opens up the actual pump casing..
Seen in the picture above..
the moving plastic diaphram on the left which provides the pumping action by moving round the casing such that the volume changes over the inlet and discharge ports...which are seen on the right hand of the above picture .. or rather the discharge ports are visible ...the inlet ports are under the rubber valves ..
A picture of the reverse side showing the central discharge port under the rubber non return valve ...and one of the inlet valves removed...showing some build up of deposits..
Again in the above picture on the right you can see the discharge chamber with another small spring loaded non retirn valve... once the water flows through there it is fed to the pump outler... and there is a small leak off to another chamber which operates the pump cut off switch...
Im guessing the pump pressure is governed by the spring that is fitted.. there is an adjusting screw on the switch which has a minimal effect on the pump cycling time
Which under test was only noticable if the pump was pumping into a system that had a bit of volume..( my garden hose which would be about 15 m long..)
Some pictures of the switching arrangement fitted to the pumps..
Cover removed...
And individual bits of the switching arrangement.
Surflo recommend the pump is mounted with short lengths of flexible hose to the system as by9 the nature of its operation it tends to vibrate a bit..
Ive noticed on my chausson the connections are to semi rigid pipes which might account for it been a bit loud... something ill get round to altering soon i hope...
And finally my set up for testing it.. reassembled after cleaning it up it held pressure overnight so it may still be useful as a spare..
Andy...
Cover removed...
Andy...
