I think that should be 23/02/22Not anymore it drops to 12gb on the 22/03/22
So same as EE then. I wonder if it will be better getting sim card in country you are visting? Can you get unlimited data sims in EU without contract?Not anymore it drops to 12gb on the 22/03/22
Easy in Portugal NoS do 15/20/30 day sims €15/€20/€30, Vodafone do similar.So same as EE then. I wonder if it will be better getting sim card in country you are visting? Can you get unlimited data sims in EU without contract?
What's the downsides, if any, to using a local sim in a mifi unit?Easy in Portugal NoS do 15/20/30 day sims €15/€20/€30, Vodafone do similar.
If you wish to stream uk based tv eg. BBC etc. You will need to use a vpn to a uk server.What's the downsides, if any, to using a local sim in a mifi unit?
Do you not have to use a VPN if use a UK SIM?If you wish to stream uk based tv eg. BBC etc. You will need to use a vpn to a uk server.
No.Do you not have to use a VPN if use a UK SIM?
If you have a UK Vodafone sim in a mifi and use it in Spain with a UK vpn, will vodafone know that you are outside you UK and limit the data usage and also charge the £2 per day when it comes into force?If you wish to stream uk based tv eg. BBC etc. You will need to use a vpn to a uk server.
Have you enabled Roaming on the MIFIWe have arrived in France and the new superdrug SIM in the huawei router won't connect to a network. It's the very basic router with just an on/ off button, it used to connect ok with a 3 SIM.
Any help greatly appreciated thanks.
To be honest i don't know the answer to that, but I would think that the European network that you were connected to would be billing vodafone UK so must know your phone number even if your data between your device and the uk server is encrypted.If you have a UK Vodafone sim in a mifi and use it in Spain with a UK vpn, will vodafone know that you are outside you UK and limit the data usage and also charge the £2 per day when it comes into force?
That makes sense, means that I will need a local sim in Spain and VPN in UK so that I can get geographical UK streaming services. Luckily my Vodafone unlimited data contract has just expired so I will be off to the O2 shop to get one of their simsTo be honest i don't know the answer to that, but I would think that the European network that you were connected to would be billing vodafone UK so must know your phone number even if your data between your device and the uk server is encrypted.
If you have a sky tv contract and wish to access sky go, you might like to consider a sky sim as some of their deals allow unlimited data whilst streaming sky go.That makes sense, means that I will need a local sim in Spain and VPN in UK so that I can get geographical UK streaming services. Luckily my Vodafone unlimited data contract has just expired so I will be off to the O2 shop to get one of their sims
That’s what I need to know too, coming back to Spain middle of MarchSo it begs the question what is the easiest way to set up a VPN to get UK TV ie BBC etc
Thanks for the correction you are right.I think that should be 23/02/22
The Portuguese NoS sim can only be used in Portugal, can't help with others.Another question !!!! When traveling through different countries in EU would you need a seperate sim for each country.
I'm presuming you do just checking. UK sims ok but they all seem to be capped.
No Lenny, I can't access the page to alter settings . I think I might buy a more sophisticated router and have the shop staff set it up with my SIM...... that'll be interesting with my linguistic skillsTigertom , have you managed to get it going yet?
