Stripped Screw (1 Viewer)
Jul 23, 2012
80
82
Kingswinford & 86230
Burstner Elegance 890
Since 2012
Anyone got any ideas how to repair a stripped thread in chipboard?
OH keeps putting tins, bottles, any other heavy stuff you can think of in the deep bottom drawer in the MH. I suspect the hinge dropped slightly, which meant the catch was only just making with the latch plate so when I went round a roundabout all that weight pulled the screw out of the drawer front. When I checked all the other screws found that most of them tightened slightly.
Catch is on inside of drawer front so need to careful of screw length so it doesn't pierce drawer front.
Thought about filling screw hole with glue, then refit screw when dry but think glue will crack, any other suggestions (useful) will be considered
Tim
3
34127
could you drill out screw hole and glue a bit of dowel in
DanielFord
3,020
3,086
I am damned if I know what the name of these things are, but essentially, it is a large bore piece of metal that you screw into the chipboard. It contains a smaller screw hole in the centre. They are sold in most DIY stores to repair stripped chipboard threads!
So all you do is drill out the hole, screw one of these in, and then screw new screws into the centre of the thingy, hope you understand my rambling! :D
JFD
Apr 9, 2015
392
238
Crawley Down, West Sussex, UK
Pilote Aventura G730
since 2014!
Fill the hole with glue, and fit the screw whilst glue still wet. That way you get max adhesion to both screw and rough chipboard hole?
Oct 1, 2013
7,511
19,934
Lanzarote
Nil by mouth
Lots
I've used matchsticks to fix rawl plugs for years ;)
Mar 23, 2012
9,541
32,047
sleights
c class
Fill hole with araldite when set drill a pilot hole just smaller than screw then fit screw in
Dec 18, 2010
885
929
Norfolk.
Autotrail cheyenne
2008-20??
Why not move catch and plate 1" left or right ?
Dec 11, 2011
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
Depends on the extent of the damage to the existing hole. The matchstick trick is great if there's not much damage and the hole is reasonably deep otherwise, like @GJH I'd go for the Cuprinol Wood Filler instead.
funflair
19,327
30,157
Guisborough
MORELO palace
since 2012
As TheBig1 and others say matchstick or I use a cocktail stick dipped into PVA wood glue, stick it in the hole snap off and then possibly other 1 or 2 and then screw the screw straight in and let it all set, anything else is just making an easy job difficult.
Martin
funflair
19,327
30,157
Guisborough
MORELO palace
since 2012
I knew Guisborough was posh but didn't realise the residents were above using common old matchsticks :LOL::LOL:
I should have add but you never get stripped screws in Niesmann+Bischoff,
But you do, especially if you are a rough a--e.
PS no matches in our van, and the advantage is that the cocktail sticks are smaller so 3 of them keep the screw on the centre of the hole, or am I taking this too seriously.
Martin
Dec 11, 2011
839
2,102
since 2010
This thread has just reminded me of one of the favourite sayings of my woodwork teacher, Dick Mabey at Sandown on the Isle of Wight, "In glue and dust we put our trust. If all else fails then putty must!"
Timotei
Jul 23, 2012
80
82
Since 2012
Thanks for all the replies. I think I'll try the cocktail stick idea and maybe some of the others if that doesn't work - but won't be trying the 'buy a Hymer' one
Tim
Badknee
7,407
412,439
notloB
Vantage Neo
Living the dream.
If that doesn't work you could try this? ;)
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I have superglued small Wall plugs into stripped screw holes before to-day? Trim it flush and screw up tight.
Pete
