- Dec 2, 2019
- 4,067
- 9,086
- Rapido 7065+
- Broken most bits now
There's no way to stop it smelling except emptying every few hours. Stopping the pong in the van needs the sink and shower traps to be working well
We find prevention is better than trying to cure. Wipe anything greasy with kitchen paper dampened with washing up water before washing and have a strainer in the plug hole to catch any food bits. Pour soda crystals dissolved in hot water down all plug holes occasionally.
We do the same. Many of the sites we use (CLs and CSs) tell you to dump the grey in a hedge, in which case I pipe it directly.When pitched I keep dump valve open to run directly to tote tank which means that just the bottom of the holding tank gets messy and smelly.
Slight change of subject what pipe do you carry and how do you connect to the waste on the tank?We do the same. Many of the sites we use (CLs and CSs) tell you to dump the grey in a hedge, in which case I pipe it directly.
I find it works well with the once every trip of top tank detergent down the sinks and shower waste removes any pong immediately.We do the same. Many of the sites we use (CLs and CSs) tell you to dump the grey in a hedge, in which case I pipe it directly.
This is a quick and easy way use a few caps of Aqua sol https://www.cleantabs.co.uk/aqua-sol.phpMy grey waste tank has suddenly developed a stink and needs a good clean, I’ve previously used elsan tank freshener but assume all that has done is masked the smell rather than cure the problem.
I was thinking of buying the fenwicks grey tank cleaner but having read about so many cheap alternatives I am here to ask which actually work.
cheap cola?
caustic soda?
bio washing liquid?
I would like a one time solution that I can do a couple of times a year rather than something I need to add regularly.
Thanks in advance.
Our Carthago came with a length of pipe and an attachment for coupling to the outlet. I extend the pipe with this bit of kit, which is very versatile.Slight change of subject what pipe do you carry and how do you connect to the waste on the tank?
Would this do it? I have a Tesco order due in the morning.
Kitchen sink either plastic or stainless steel. Level sensors stainless steel. Anything aluminium would have a very short life in any drainage system regardless of the use of cleaning chemicals.Do NOT let it contact aluminium !
Your kitchen sink is probably aluminium
The level sensors are probably aluminium
We've been using that in the cassette for several years. It does break down solids, prevents smells and keeps the cassette clean.I poured half a bottle of Lidl, Formil, Bio Laundry Liquid fluid down the three plug holes. Half filled the grey waste tank with fresh water, went for a 30 minute drive to agitate and swill around left it fo a week before draining away.
Not a smell since and I've been using the rest of the bottle in the toilet cassette, not totally convinced on its ability to 'digest' the toilet waste yet. However that also smells sweet, both when emptying and when you oen the flap when you use it.
Formil Laundry Liquid BIO, £1.49.
Cheap Cola???
Whoever thought of that?
It's literally all sugar!
Common issue. The u-bend traps normally prevent the smell from coming back up the drain holes. But when you're driving, the air pressure and movement shifts enough water for the grey tank to vent back...I only get the smell when driving !...Parked up for a few days,...no smell,...Drive off, smell returns. Have tried All of the above, Full/Empty, makes no difference, and judging by the distance of the vehicles behind me,..they can smell it too !
