Stiff swivel seats
Oct 15, 2007
3,001
4,903
Neckend or North Wales.
Now own a static
Since 2004
As anyone had a problem with the front swivel seats as our Globecar is now 9 months old and I’m finding that the seats are getting stiff when first turning them around.
Also when you turn them back the last bit is very stiff but they are quite loose in between.
John.
Lenny HB
32,443
61,708
On the coast in West Sussex
Hymer B678 Dynamic Line
Depends on the type of swivel, if they have the large centre nut just loosen it off a fraction make sure you will re-apply some thread lock.
Oct 7, 2013
4,665
29,496
South Wales
Swift Escape Compact
Since 1988
Do you have to remove the seat to reach the Centre nut? Can’t see one on ours and one seat is slightly loose. It’s not the runners that need tightening, I’ve checked.
Lenny HB
32,443
61,708
Our first Hymer had ISRI seats and you could get at the nut from behind with the seat fully forward, they are not that tight I used water pump pliers. I had the opposite problem nut worked a tiny bit loose and the seat would move a couple of mm when braking and cournering not much but quite a shock when driving. I took the nuts off and applied some thread lock and re-tightened them until the seat would swivel easily but still firm.
PeteH
6,862
9,027
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I lubricated the seat swivel (FIAT) with spray grease via a "straw" nozzle, that improved things for a while, getting so it needs doing again though. I also notice it tends to bind if I have it extended, say when using it to access the table.
Jul 12, 2013
3,066
3,605
The City of Henlow
Adria Supreme
Since 1980
As the problem has become an irritant for you, take the seat off , they can be quite heavy and investigate the effectiveness of the rotating plate. You should find this a simple job which will also allow you to get at the parts that get dusty where you cannot easily clean them.
Oct 7, 2013
4,665
29,496
South Wales
Since 1988
Many thanks. (y)That’s the problem we have.
Unfortunately, the centre of our swivels are open to allow cables to pass through. There is no Centre nut.:(
Jan 24, 2013
81
34
Near Bristol
Autocruise Rhythm
Since 2012, so still learning
This was an ongoing problem for us as well. Dealer kept oiling things but i was convinced it was a fault in the bearings, despite them telling me there were no bearings. Had to show them in the end. Stiffness was at the end of travel, in the straight ahead position. All cured now, it was two small rubber blocks at the front that the seat rides up on as it locks. Removed and kept them, but swivels fine now. These are the Fiat seats with no central nut. Try this.
Neckender
Oct 15, 2007
3,001
4,903
Now own a static
Since 2004
I’ve seen those blocks and I will try that tomorrow as well as silicone spray.
Thanks all.
John.
