VikingBen
- Dec 2, 2021
- 5
- 0
- van conversion
Ahh ok will run the van tomorrow and see if that helpsLow voltage....the Inver will only operate between certain voltages, too high or too low and it will stop working
Either the battery is flat or the wiring inadequate size.
Ok so if I run the van in the morning for a while is should work again is that right?Yep...it's a sib 121600, not a sib 241600 so 12v.
It alarms at 11v and trips at 10.5v
If it's in use powering something it will drag the voltage down below the batteries 'at rest' voltage quite fast.
