Lenny HB
- Oct 18, 2007
- 53,404
- 149,850
- Hymer B678 DL
Not really a dilemma, as I fairly certain I am going to replace it, would be interested in a bit of feedback from the techies on here Raul ,autorouter etc.
Went out to the van to move it a couple of weeks ago, starter started to turn the engine over then the battery died & all lights went out on the dash.
Left it a few minutes then turned the ignition on to measure the voltage at the cigar lighter socket, not as good as direct on the battery but easy. The compressor for the air suspension started up and the battery voltage was 9.7v, after the compressor stopped battery reading was 11.2v gradually rising to 11.7v.
Left it overnight and it took some charge and was now at 12.55v & engine started fine.
My setup is 3 x 78 a/h Gel leisure batteries with 300 watts of solar via a Votronic 350 MMP regulator. Starter battery charging taken care via a CBE CSB2 relay which switches on when the leisure batteries are at 13.6v and off at 12.6v., and charges at up to 4 amps.
Mains charging via EBL 30 this only charges the starter at 2 amps, so I don’t normally plug in at home.
With the CBE relay and no draw on the leisure battery the starter battery should get a charge all day and probably 24/7 but to be sure I plugged the mains in and left it for two days.
Measured the voltage directly at the battery now at 13.55v.
Disconnected all charging methods and left it for an hour now at 13.1v
Left it with no charge and have been checking it daily. The system draw is approx 80ma (flips between 70 & 80 ma).
These are the results.
Today is Day 16, tried starting, started OK although turning over was slightly slower than normal but to be expected.
The Battery is 95a/h allowing for it being 4 years old it is probably down to 86 a/h.
The battery is down to approx 50% by day 13 by my calculations it should be at that level at around 23 days so looks like best to replace it.
My concern is why it went flat, we did have a couple of very rainy, cloudy weeks with virtually no solar input but the SB would have still got some charge via the CSB 2 relay.
One theory is the with the van sitting a while the air suspension compressor cuts in if the bellows lose pressure, the system is normally only live for 8 min after the ignition is turned off but I don’t know what goes on in the background.
The compressor draws 30 amp but normally only runs for a few minutes. I’ve emailed Goldschmitt but not received a reply.
I think I will replace the battery for the sake of a 100 quid not worth the risk.
I can get a Yusas 5000, 100a/h CCA 900A for £105 from Halfords with my trade card the standard price is £143 and Battery Mega Store are £113 so not bad. The original battery is 95a/h CCA 680A.
