Does anybody else have brakes that squeal whenever you approach a junction or come to a halt? Any solution? We have a 2021 Ducato based motorhome. TIA
The 'usual' cure for squealing brakes, was pads out and a thorough clean, perhaps a thin smear of grease on the back of the pads.Does anybody else have brakes that squeal whenever you approach a junction or come to a halt? Any solution? We have a 2021 Ducato based motorhome. TIA
Just make sure its copper greaseThe 'usual' cure for squealing brakes, was pads out and a thorough clean, perhaps a thin smear of grease on the back of the pads.
And don’t put it on the front of the padsJust make sure its copper grease![]()
DanielHey Shropshire lad
My 2021 Ducato is the same. Squeal from front brakes has become really bad and it is booked in to have it looked at under warranty a couple of weeks time.
I am on 16,000 miles
The Fiat Professionals garage was not surprised at the compliant ….
Daniel
That's what vaseline is for.And don’t put it on the front of the pads![]()
I had squealing back brakes when approaching junctions in my 2016 boxer (possibly same braking system)Does anybody else have brakes that squeal whenever you approach a junction or come to a halt? Any solution? We have a 2021 Ducato based motorhome. TIA
Irelaced all four disks and pads because they needed replacing but the squealing continued, I figured it was the hand brake was causing it so I stripped them out, cleaned everything and checked cables etc. but the squealing continued
Figured out it was a lever under the front end of the van which operates the handbrake bar when you pull the handbrake, it was half seized, so when you released the handbrake the shoes were still making slight contact, haven't had a squeal since freeing it out.
A bit long winded sorry but hard to explain.
Hope it helps, Liam
Sorry, but that has not seen any lube from new. Who has been servicing the vehicle?
As an update.
Fiat Professinal say yes they squeal - but Fiat won’t do anything , I would have to pay for new discs and pads …. Despite the fact that is the third time it had been in for this fault.
Currently I am arguing with Fiat customer service a sit reported the fault first at 6 months old they should sort it
As it is nearly out of warranty at two years old , 20,000 miles if I get nowhere with Fiat I will strip, clean and properly lubricate the right bits with proper ceramic grease and see what happens.
I should not have to but I don’t have the time to keep taking it back and wait all day for them to say of it is fine ….and lose a days holiday.
Daniel.
