They are crap, but in your use case probably sufficient. Sounds like a faulty one.Thanks for reply.it’s just a basic campervan with durite split charge relay.no solar or outside charge.
Was working fine and I realise they stay on a bit after engine turned off.but now mine stays on all time even if take fuse out or remove cable from battery
If the light stays on after you have removed both power feeds, probably there is some energy storage inside the electronics of the unit. Something like a 'capacitor' which acts like a storage tank to smooth out glitches and keep the electronics going during switchover operations. If the only thing draining the capacitor is a single LED, then it can keep going for quite a long time.What I cannot understand is when I remove the positive feed from starter battery to relay it still lights up.how is this possible without a feed?even when clamps removed from LIESURE battery.
Where is power coming from?
There's two main problems if the relay is permanently closed. First, when the starter motor is running, it takes a very large current from the starter battery, for a few seconds. If the leisure battery is connected via the permanently closed relay, it will try to contribute to that large current. It may possible damage the battery or blow the main leisure battery fuse.Relay is working as with engine running volts same as starter battery. I'm gonna ignore it few days and hopefully not draining anything. Maybe overthinking things. But definitely from he fitted heater
If you remove the fuse at the starter battery end of the feed wire, that will stop any amps flowing along the wire. It will stop the alternator charging the leisure battery while the engine is running, but if you normally use EHU on campsites that won't be a big problem. The habitation electrics will still work OK if you do this.Electrics confuse me i seem to have a brain freeze when trying to work it out.what do you suggest to solve?I usually use campsites anyway with ehu if that makes a difference
Yes you can, depends on cable length and size of the B2B, 16mm sq will be fine with a 30 amp B2B, I wouldn't go any higher unless you know you have an uprated alternator.Without starting a new thread is it possible to remove relay and replace with B2B charger using same cable’s.16mmsq.is it as simple just swapping over or more to it?this has probably been mentioned before but just wondering if as easy as straight swapover?
It's the length from the B2B to leisure battery that's important. Voltage drop on the starter battery side will be compensated by the B2B. For comparison, 2 x 5 = 10m of 16mm2 wire at 30A will have a voltage drop of 2.7%, which is better than the standard 3% guideline.about 5 metres cable between batteries.
