We have a rapido 604 it had a solar panel with dual battery charging. I have not come accross a split charge system, does rapido fit them as standard. Where might it be hiding .
Unfortunately, on the older CBE DS340, I don't have that facility, so I'm in touch with a mobile Auto Electrician (also a MH'er), to come and install the relay setup that Pausim installed and posted of. I provided the Sparky with the CBE diagrams which he clearly looked at, as he identified the correct cable and terminal which we should tap into, (without my input), as well as understanding the CBE battery pairing, and my need to isolate the cab battery from that, but only whilst the engine is running. He is also ofay with Sterling and Victron/Votronic B2Bs.Yep
R37 cut. The box is in a recess, so accessibility poor. Just able to use wire cutter on centre of zero ohm resistor.
The leisure battery now isolated from sb when engine running. Ie as required. The mains charger does work on both (with lb not fully charged) I've since fitted a b2b and lithium battery, works a treat. Some wiring needs tidying up though.
You can see the board was original laid out for a swtich.View attachment 484525heres the offending" resistor "
JockandRita
I know the pauism threads and relay approach. I started this then found others. I just added the end result to complete this thread.
Glad you got a guy who knows what hes doing.
steven2002 if yours does not have r37 as above see the thread
Very imformative.Carthago Split Charging Unit
I'm exploring the possibility of putting a B2B charger on my Carthago, but I understand that I'll need to disable the existing split charging unit. Does anybody know where it is? Is it a separate unit, or is it built into the electronic gubbins in the boot? I can't even identify a fuse for it...www.motorhomefun.co.uk
Having read your comment on a previous thread i was intending to add one to test reversiblity. It looks as if the electrical system is laid out early in construction and a box built around it (with an accessability hatch) without a total stripdown in my case board access is "difficult ". It was with trepidation that i cut the resistor knowing wardrobe dismantling was a possibility if it didnt do as expected. But it all works as expected. Including taking D+ of the white wire.You can see the board was original laid out for a swtich.
Is there a switch?
Yep, I hunted high and low, but not found on the DS340 board.heres the offending" resistor "
And it's with a similar level of trepidation that's made me get a Sparky in to do what needs doing, as I'm not confident enough of getting it right first time.It was with trepidation that i cut the resistor knowing wardrobe dismantling was a possibility if it didnt do as expected. But it all works as expected.
Which location is that?Cut the R37 resistor on mine And the 3 amp fuse at position number 10 is over heating
It is in the CBE DS300 unitWhich location is that?
The only fuse 10 i can get refference to is the 10A horn fuse in the engine bay.
In order to have a cbe with r37 van is post 2006?
Thanks for bringing this to our attention. I now have the need to check it
DohIt is in the CBE DS300 unit
I totally get where you are coming from the1andonly, and I have done many a job myself which has resulted in minimum costs with hours of self labour, compared to quotes from the "so called" professionals, but there are times when I am out of my depth, (and not afraid to admit so), where I need to call upon more learned advice/help. I know what I want, and what needs doing. I'm just not confident enough to do "this particular task" myself, as I have never wired up a basic relay, never mind a 5 x terminal closed relay with differing diameters of cables and connections.JockandRita i always have had difficulty paying someone to to a job. Its a matter of trust i suppose.
Been let down too often?
My last hab check (warranty required) confused me :
Gas sytem i have been concerned about the regulator duo system, they said ok but a leak in the bbq point.( not obvious to simple tests) fault repaired gratis.
Electric bed on 3 previous visits ive mentioned the bed issues they have always said it works, weve done nothing. This trip ive no problem with the bed having sussed how problems can occur, their statement weve fixed the bed. No details available.
That's the one!Doh
Numpty alive and well
Will check it out eventually just been pruning a tree.
Is the D+ fuse10
