Hi All
Well where do I start I took my vehicle to Mick at SAP due to having such an appalling job done by another company when I had my E&P self levelling system fitted and I wanted it checking out.
Mick said he had never seen such a poor job Mick refitted the system correctly and I now have all thepipes running outide the vehicle where as before I had about 8 ft of hydraulic lines running under my bed operating at nearly 200 bar and which had joins in them so imagine the mess if I had had a leak.
The detail SAP went to was superb all my levelling jacks are now fully under sealed where before they were just left painted so after time would have started to rust, all the hydraulic lines are now correctly insulated around the exhaust and engine areas where heat could cause a problem.
I went to Mick after reading great reviews on here from his customers and I am so glad I did as I now feel everything is correct and as it should be.
If you are thinking of having any work done on your MH give them a call they do all sorts of work and whilst they had my vehicle in I had a 150w solar panel installed on the roof and a sog system fitted to my toilet again the work is faultless.
Thanks to all at SAP
Cheers LB
Cheers LB
