Spare Thetford Cassette (1 Viewer)
Oct 5, 2016
53
21
Kent
Ci Mizar Gtl
Newbie
Hi, I would like to prepare my motorhome for times when we could be self sufficient for longer periods. Quite happy with the size of the water tank and no problem with the grey waste, have added an extra battery and inverter (will install solar asap). Just scratching my head at the moment as to the best way of carrying an extra cassette for the Thetford toilet. Would ideally like to design a way of descretly carrying it underneath. Has anyone got any clever solutions or designs they are willing to share? Thanks in advance as always!
Lenny HB
52,700
147,648
On the coast in West Sussex
Hymer B678 DL
Fiamma make an underslung carrier not cheap about £100, doesn't look that easy to get a full cassette in & out of.
Notski
Oct 5, 2016
53
21
Kent
Ci Mizar Gtl
Newbie
No problem carrying a clean empty one inside but as soon as the other is full and then have to swap them over wouldn't be happy having the full one inside. Will check on line for the Fiamma solution but am trying to keep the budget a bit lower for the moment, thinking someone may have come up with a low cost smart idea I could borrow(y), maybe a simple bracket using the original quick release/lock!
icantremember
8,318
17,527
Near to Watton in Norfolk
Hymer T-SL668
since 2005
On the VERY rare occsaion we have used the spare we carry it in a poly sack in the shower with no problem ... if well maintained there is no smell or leakage.
Feb 4, 2016
2,784
2,127
West Sussex, UK
Hymer B680 Starline
Long term a few years now.
We keep our spare cassette in a holdall in a belly locker . Not used very often but it is outside at least.
Minxy
32,489
66,017
E Yorks
Carthago Compactline
I rigged something up under a previous Chausson MH to carry a black waste container using an old plastic coated freezer basket (a strong one), some brackets, hooks, chain and a padlock ... it actually worked very well and could be adapted to carry a 'proper' cassette if needs be.
Apr 27, 2008
11,794
13,956
Eastbourne East Sussex
Hymer low profile
Since 1972
My spare cassette lives in the back box on the bike rack (we don't carry bikes). I have only had to use it once though. If there was a full one it would go in the same place, in a plastic box in case of a leak though they are pretty leakproof.
Notski
Oct 5, 2016
53
21
Kent
Ci Mizar Gtl
Newbie
Thanks, impressive design, has given me a few ideas, would like to try and come up with something that uses the original slide and click into place and release, using the yellow lock lever. Maybe I would be over complicating things!
Minxy
32,489
66,017
E Yorks
If you are concerned about 'leaks and smells' get yourself a waterproof bag to put it in, something like the below ... it also means that if you need to empty it in a toilet block (cleanly of course) it's less obvious what you are carrying:
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Or alternatively, buy a motorhome with a 45gal black tank. Now, let me think, who has one of those ? :)
Minxy
32,489
66,017
E Yorks
I'd be wary of using the existing slide/clip etc ... if it gets damaged you won't be able to use the cassette ... better to use something else to secure it within a box of some sort ideally to keep it clean and it would probably be easier to make as well. For example if you had some sort of crate/box like the below and cut off the end and made it hinged, then fixed the crate to the bottom of your MH you could slide the cassette in and then secure the flap ... you'd need to make sure the crate was strong enough and secured well enough to support the weight of a full cassette. Another alternative is some sort of rubbish bin with a lifting lid mounted horizontally in the same way ...
Nov 6, 2012
196
279
Guildford
3litre Bessacarr 765
Restarted 2012
I carry our spare cassette in a locker between the floors in an old Sainsbury's blue shopping tray. I had to put about an inch of polystyrene in the bottom to raise it up so that it fitted perfectly. It is pre-charged with the correct amount of 'blue' for a quick swap over. (Why does the full light always seem to come on during the night or first thing in the morning!!!??)
Lenny HB
52,700
147,648
Hymer B678 DL
That looks useful for a secret dump in a public WC, it van I found a storage crate that is a perfect fit.
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Our spare is wrapped in a very large polythene bag then put into one of those plastic folding crates in the garage. The crate is the perfect size for a tight fit but the emptying spout sticks up about an inch above. Still OK to stack other things on top though.
Richard.
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Really useful boxes do a variety of sizes. There might be one suitable.
Feb 9, 2008
4,086
5,902
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
May be oversimplifying things but could you not just carry a black 25 litre jerrycan and decant the cassette when its full?
icantremember
8,318
17,527
Hymer T-SL668
since 2005
Great idea ...
... then you could empty it down the grey waste points on C&M club sites without the wardens realising until too late.:whistle:
Apr 10, 2010
548
538
Bedfordshire
Carthago
Since Sept 2003
Our spare sits in a locker between the floors, accessible from the outside. Although this is a dedicated space for a spare cassette, I can't see any objection to carrying a full one in any locker or a garage. They don't leak when they're in use in the toilet, so why should they leak at any other time?
denisejoe
5,565
11,650
Warden isle of sheppy
Since 2004
We've got one of the Fiamma ones. Wouldn't buy one but it was already fitted when we bought the van.
Have actually only used it once. Quite difficult to get a full cassette into.
