Spanish and french gas bottle adapter?
Thaxted, Dunmow, UK
Rapido 7066DF Ducato
Since 2023
Hi,
Heading down to Spain in few weeks and around France later in year. Not ready to go down refillable route yet. Will a spanish pass thru adapter (jumbo and appropriate pigtail) that fits spanish bottles also fit French ones or must I get a French adapter too? If so, are the empty bottles interchangeable for replacements if I pickup a used one in spain at a Chinese shop or market??? Thanks....
No. The Spanish jumbo adapter does not fit the French bottle. Also be wise to buy the jumbo adapter here in UK before the trip, they seem harder to obtain in Spain.
Regulators are everywhere but not the adapter.
  • Informative
Reactions: f6c
Ahhh righto.. have Hamilton gas lined up for a Jumbo purchase... any idea what french adapter is needed pls...?
We arrived in Spain a week Ago and have not been able to buy the high pressure hose yet, but I can fill up less than 3 miles up the road if I drive up there it looks like we should get 3 weeks out of 2x11kg bottles Gaslow
Sorry know nothing about the french bottles. Posts on here in the past seem to suggest it's pretty easy to buy French bottle and the pigtails needed. 👍
When I used to use the Spanish bottles I always left Spain with a full bottle as it's cheap enough.
Reactions: f6c
A large French bottle (about 13kgs) is readily buyable at a French supermarket and has an outlet that can be fitted to the end of a UK butane pigtail (ie a left hand threaded 21.8 Pol, female)
All you need to do is buy that pigtail before your trip, screw one end into your Regulator and screw the other end onto the bottle.
That same pigtail will screw onto the Jumbo ADAPTOR if you decide to buy or obtain a Spanish bottle.
Hi,
21.8 lh pigtail and a 27mm Jumbo clip on adaptor.
21.8 lh pigtail and a 27mm Jumbo clip on regulator
"21.8 lh pigtail and a 27mm Jumbo clip on adaptor
You do NOT!!! want a regulator.
Assuming your motorhome or caravan has a bulkhead Regulator in the gas locker (standard since about 2002) you require an ADAPTOR.
If you fitted a regulator on the Spanish bottle you would be regulating the flow of gas twice.
An adaptor is basically a shell without the internal gubbins (technical term) to allow you to connect the bottle to the Bulkhead Regulator.
"21.8 lh pigtail and a 27mm Jumbo clip on regulator????"
Changed , typed regulator for some reason 👍
Definitely Adaptor
Definitely Adaptor
I've changed my original post as well (for clarity)
Unfortunately I can't change the "quoted" post but I'm sure the OP has now got it that, if there is a bulkhead Reg. you need a Spanish ADAPTOR!!! Yes I know I'm shouting!!!
Thx guys... I already have a bulkhead reg (2011 Van) so understand its the jumbo adapter I need for spain. Now know I need a different adapter for France but the pigtail fits either Adapter... (y)
Sorry correction, pigtail fits jumbo adapter for spain and screws onto french bottle.... have I got that right Emmit/Basildog? Cheers for advice guys.
Pigtail fits direct onto french bottles (only the big ones)
The pigtail fits the Spanish Jumbo adaptor.
Here is the jumbo adapter in place on a Spanish Cepsa bottle in my previous van.
You dont seem to see this type about much now but the one in the second picture does the same job.
The thread takes a standard Butane pigtail as mentioned above, so pretty swopable (remember a spanner). (y) ;)
  • Nice One!
Reactions: f6c
Thanks Tonka... going to get the adapter and pigtail today.... can you confirm if that's a 11kg (large bottle) and it's height and width? Struggling to find dimensions online and wondering if it will fit in my small locker..!! If not, then I will need a long pigtail, around 3 feet which Hamilton Do stock and keep bottle outside ...
