Sorry, toilets again
glenn2926
Gods country
Chausson
newbie hired 3
Do any of you know if I can replace the blade only in a thetford c260 holding tank. Mine has fallen off. This the black disc. I cannot see how it is held in place as it doesn’t have any screw hole or clip on it. There does however seem to be a slight star shaped mark in centre of it. Has something snapped off?
Thanks in advance.
As shown in image - fits inside holding tank
The small centre locating knob is designed to break off if something gets caught in the closing to prevent additional damage.
That will be the little star shaped bit you see, the remains of the locating pin.
about £6 on ebay
Yes you can buy just the disc it’s self. Just swapped mine. Got it on eBay, but came from CAK tanks. There are copy versions, or proper Thetford part. I went Thetford.
I just knew some of you would know. Thanks pappajohn that picture shows it perfectly. I will get to eBay now.
Thanks all for the help.
The box has the full fitting instructions inside. (The Thetford item)
different model same method
