- Jul 6, 2009
- 2,236
- 2,820
Sorry if this is a long post but not the best at explaining. Having recently had a lithium upgrade, as previousl posted we have 700 watts of solar a Victron 2000/80 multi and 2 x 100 amp transporter Lithium batteries.
as we are still waiting for good old DVLA i thought I would have a little play and found the following
the Genny is a Honda EU10i running on lpg.
using the inverter only running the Dometic Fresh jet 2200 set to max cooling draws 103.3 amps with the Genny set at 4 amps @ 240 the battery consumption falls to 55 amps. Setting the Fresh jet to max heating uses 83 amps dropping to 33 amps with Genny set at 4 amps
Truma heating set at 1kw draws 83.1 amps again dropping by app 50 amps when Genny flat out, 2 kw draws 195 amps again dropping by app 50 amps with Genny set at 4 amps.
Dometic fridge on mains supplied by inverter only takes 15.4 amps,
Genny only charging the batteries through the multi, set mains input at 2 amps Genny stays on its idle setting producing 30.3 amps to the batteries, up the incoming from the Genny to 2.5 amps produces 36 amps Genny just a fraction above idle, up to 3 amps Genny increases but not flat out produces 43.3 amps, upto 3.5 amp from Genny produces 48.7 amps, Genny flat out 57 amps charging.
this again is not about the pros and cons of using a Genny but simply to give anyone who is interested some idea of what uses what and what produces what
