From Vanbitz who fitted the system yesterday.Where you getting the 8amps figure from?
It all depends on what you take out, 520watts is enough for us when the sun is average and more than on a good day, the more you have the more you useFrom Vanbitz who fitted the system yesterday.
Initially they were going to fit a 175 watt panel which was the size I was after but after looking at my roof yesterday morning they said there was only room for a 115 watt panel.
I'm just a bit concerned that 115 watts won't produce enough amps.
How to calculate AmpsFrom Vanbitz who fitted the system yesterday.
So are you saying that it won't produce what Vanbitz said ?
Vanbitz will gave quoted what the panel specified at.So are you saying that it won't produce what Vanbitz said ?
I know that, the link was for people who didn't. Some people think with a 12V panel you will divide say 115W/12V which will give you 9.5 amps, but you should divide the Watts by the Maximum power Voltage figure. So say it's a Victron panel as in the following Link it will be 115W/19V = 6.05 Amps.Amps are simply a product of watts and volts, the unit of power is watts, on a good day and a tail wind the panel will produce its rated power in watts, how many amps your battery sees is down to the voltage W=VA therefore A=W/V.
I think the 40 amp-hour yield per day that funflair calculated is a good ballpark figure. Day length will vary, depending on the time of year and also the latitude, big difference between Norway and Morocco.I know that it should produce about 8 amps an hour peak but am just wondering roughly what it would produce over a day in total if it was bright sunshine all day.
But if you want the solar controller output, the voltage when actively charging will be about 14.4V, so the amps will be 115/14.4 = 8 amps.Some people think with a 12V panel you will divide say 115W/12V which will give you 9.5 amps, but you should divide the Watts by the Maximum power Voltage figure. So say it's a Victron panel as in the following Link it will be 115W/19V = 6.05 Amps.
Doesn't it depend whether you want to know how many amps the panel is producing or how many amps are going into your battery ?I know that, the link was for people who didn't. Some people think with a 12V panel you will divide say 115W/12V which will give you 9.5 amps, but you should divide the Watts by the Maximum power Voltage figure. So say it's a Victron panel as in the following Link it will be 115W/19V = 6.05 Amps.
Unfortunately the single 115 watt panel was all Vanbitz had room to fit.God result, you can't beet a real world test to put your mind at rest, now start using more power and you can have more solar and more batteries
As you say it's providing enough to cover what you use so why would you want to pay for more?. I think it's like everything to do with motorhoming you can pay for ever on self leveling lots of solar tons of payload then of course it will need a new huge motorhome that drinks like a fish etc etc. If your set-up does what you want I'd say on the basis of stick or twist....... stick!Unfortunately the single 115 watt panel was all Vanbitz had room to fit.
That’s the panel amps. The controller will push 9-9,5A in bulk.I know that, the link was for people who didn't. Some people think with a 12V panel you will divide say 115W/12V which will give you 9.5 amps, but you should divide the Watts by the Maximum power Voltage figure. So say it's a Victron panel as in the following Link it will be 115W/19V = 6.05 Amps.
That’s only true, when the charging hit the CV absorb. Before that, in bulk the battery voltage it’s lower, and specially when under load the voltage will sag allowing max power in if available from the panel.But if you want the solar controller output, the voltage when actively charging will be about 14.4V, so the amps will be 115/14.4 = 8 amps.
You could have a folding panel as a reserve. The photo shows a snapshot taken of the panel in action recently in France. You could wire it direct to the hab batteries via an Anderson plug, so easy to connect and disconnect.Unfortunately the single 115 watt panel was all Vanbitz had room to fit.
Sounds like you need more wine more than more solar!Yes my usage was pretty constant at about 15 amps per day.
The last day the solar replaced 2 days use by 1.00pm
I could probably double my usage to 30 amps a day and the solar would replace it, provided the weather was ok.
I've got 2 X 100AH lead acid leisure batteries so 100 amp usable, although personally I'd err on the side of caution so 80 amps usable power.
At 15 amps use per day that would theoretically give me about 5 days even without any solar.
