Solar to engine batteries (1 Viewer)
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Solar panels on all day when or how does it switch to engine battery from leisure? To start to charge as the engine battery is standing at 12.3v
Sargent 500 system 2013 Auto fail
P's on a hook up it switches itself?
Jan 26, 2017
3,474
11,739
Mid Suffolk.
Autosleeper Inca
Eight Years and 28,000 Miles.
On my 2004 Inca, the(after market) solar panel doesn't charge the engine battery at all, I recently fitted a Battery Master.. problem solved.
No need for EHU at all, both batteries kept topped up, highly recommended...dead easy to fit too.
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
I think the auto fail has a system something like that.
funflair
19,343
30,219
Guisborough
MORELO palace
since 2012
The trouble is "something like that" might not be close enough, our van has the CBE system and charges the starter battery when on hook up and also on solar IF the leisure batteries reach a high enough voltage to make the switch which in the winter they don't so Battery master = sorted.
Martin
Nov 7, 2015
497
469
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
If yours has a Sargent EC500 using the control panel (EC480 ?) check that the "Solar Charge" setting is set to "Smart Charge" on that setting it should charge both batteries
