The memsahib and I have this week "retired" at 48 and the tunnel is booked for 20th Sept with a vague plan to "turn left at the exit" and see where we end up. We'll be doing perhaps 3 long trips a year, followed by summer in the UK to top up the piggy bank.
This necessiates a few upgrades to the van, as we intend to be wild/off-grid a fair amount and I'd like to be able manage a week to 10 days if needed, without needing hookup/dumping.
I'm in the final stages of designing the solar system. Annoyingly although it's a 7.4m van, roof real-estate is a bit compromised as all the longitudinal gaps are a couple of cm short of the roughly 99cm width needed for large single panels. So I'm having to go for more but slimmer panels.
Usage and wishes
Our 12v usage is a bit of TV, lighting, recharging phones, laptops, tablets, aand the usual water pump/heating blower, etc. I'd like to reduce gas usage by converting extra solar to run the fridge when the batteries are full. Ideally I'd like to be able to charge 2 e-bike batteries/scooter as well - not every day, but I know they take quite a whack out of a battery.
Plans
I am planning 200ah of AGM batteries, 2x150w rigid panels probably with the voltronic MPP 350 Duo controller (if I can find one). I can't afford fancy lithium batteries. This would enable me to trickle charge the starter battery when the hab batteries were full, and send a signal to the fridge to use 12v too when the habs are full.
I think I probably need to have a separate 100ah deep cycle battery and smaller panel and cheap MPPT (or maybe really cheap PWM) controller to run the e-bike charging set up - as I can discharge it further without risk of damaging the main leisure bank. I'm planning to use a variable DC-DC converter rather than an inefficient inverter.
I've just about finished the engineering prototype for a simple motorised tilt system - using a linear actuator, remote control and an aluminium frame. Just need to get the panels to try it in anger.
Questions.
1. Does that plan sound reasonable? Any other suggestions?
2. Is it sensible to have the separate system for the e-bikes with a DC-DC converter? I reckon a 100w panel is probably enough.
3. Anyone know where I can get a MPP 350 Duo from? Global shortage it seems...
4. If I can get the motorised tilt system to somewhere between £50 and £100 - is this a price point that might make it viable to make/sell as a kit to others? There's nothing really on the UK market, unless you want a v expensive tracking system. I know it's as cheap to get a second panel at that price - but not everyone has the space or would perhaps also need to upgrade other components in the system for more panels.
Thanks as always for comments and suggestions.
Robin
Usage and wishes
Plans
Questions.
Robin
