That's interesting. . I often pop the fuse out between controler and regulator without isolating the connected panel to check the current... I never gave damage to panels any thought..Similarly, if you need to take the batteries out of circuit for any reason in future, disconnect the panel from the regulator first, or cover it to block out the sun.
Not sure I follow you Andy. In my mind, controller and regulator are different terms for the same component.That's interesting. . I often pop the fuse out between controler and regulator without isolating the connected panel to check the current... I never gave damage to panels any thought..
As the blurb seems to indicate the controler has plenty protection built in..
Andy
Sorry Philip yea should have said controller or regulator....Not sure I follow you Andy. In my mind, controller and regulator are different terms for the same component.
Always connect the regulator to the batteries before connecting the panel to the regulator. If you do it the other way round there is a chance the regulator may be damaged. Similarly, if you need to take the batteries out of circuit for any reason in future, disconnect the panel from the regulator first, or cover it to block out the sun.
I have a fuse at both places , mostly for isolation purposes.Very interesting in my set up the fuse is on the lead from the controller to the batteries. Are you saying the fuse needs to be in the lead from the panel to the controller?
It's correct that the battery should be connected first, but when disconnecting apparently it makes no difference. I asked a question regarding removing a controller to battery fuse here:
http://www.motorhomefun.co.uk/forum/threads/controller-to-battery-fuse.151196/
