Solar on a budget. (1 Viewer)
Oct 19, 2017
257
183
Cornwall
Class C?
Returning to a motorhome.
I want to fit solar power to our wee Autocruise Vista, on a budget. If I do it, it has to a viable set up. Is it worth thinking about a used system? Is there much available? Are kits any good or just cheap tat? I have read numerous posts, but am not particularly au fait with what is available and of any use on the cheaper side of things, or indeed what components are a must have, rather than a useful addition. Sorry if this subject has been flogged to death, but so far this forum has been a godsend. Cheers John.
Lenny HB
53,315
149,511
On the coast in West Sussex
Hymer B678 DL
Depends on what you are trying to achieve.
1) Do you just want to keep the batteries charged when parked up van not in use.
2) Survive a couple of nights off grid D.
3) Survive for longer periods off grid.
With the panels, the cheaper ones generally perform well it is just the frames aren't as strong as the dearer ones, although don't know what the longevity is like.
Cheap regulators work but not much good in low light conditions, if you are going to rely on the solar well worth spending on a good MPPT regulator.
Even if you only keeping the batteries topped up make sure you get at least a 2 stage regulator preferably a 3 stage one if you want your batteries to last.
Camping Gaza
993
1,467
La Châtre, Centre-Val de Loire France
Coachbuilt Low profile
Converted a Fiat Ducato PV a while back
Don't get a kit it will be too expensive and one or more components will be tat.
Decide your requirements and buy individual components. You dont need fancy meters, the solar controller once set up will do all its stuff automatically.
Don't expect the holy grail of harvested power in this country, there just is not enough sunlight here.
claims of 100watts out of a 100watt panel is plain fantasy unless you are standing on the surface of the sun that is!
A good MMPT controller is bettr than a PMW one but considerably more expensive and you have to ask is it worth it.
Cheap 10 quid controllers on ebay amazon are IMHO just not worth it, but dont be hoodwinked into a cheap one "rebranded" as expensive. ( look and you will see they all look the same)
Photonic universe website is worth buying from (google it)
I Use solar (300w on the roof) and on a cloudy day in the UK I get about 3 amps (depending on state of charged batteries) but in spain, a different story!
I also have a B2B, and find that to be the best solution.
Do you research and understand HOW solar systems work and you can do it on the cheap
