Solar display wiring help (1 Viewer)
Jan 31, 2016
1,901
3,377
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
I've got a small LCD display
which needs wiring live/neg supply and live/neg load.
I have two solar panels wired through a Schaudt LRM1218 and unsure of how to wire this display up, to pick up supply and load, has anyone fitted a similar display ?
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
You Tube is your friend- there is a couple of videos shownig how to wire it up.
scotjimland
2,309
9,979
A Woosh bang
I'm afraid what you have bought is unsuitable for solar power measuring.. this is for measuring AC current using a CT coil.. , wiring digram is in the pictures..
BusyBuilder
Jan 31, 2016
1,901
3,377
Hymer B544 (2012)
newbie
Scotjimland, are you by any chance on UKGSER forum ? ( I bought a Garmin from someone with very similar name)
If you look at the pictures of the item there is one that's DC, which is what I've got, I assumed that I needed the DC one ? if so any ideas wiring it up ? cheers
Lenny HB
53,417
149,915
On the coast in West Sussex
Hymer B678 DL
I fitted a similar on to my last van, with those size connectors it and the unit does not look big enough for an internal shunt.
I think you are going to need a 100 amp shunt and connect to the unit using the 3 wire method.
BusyBuilder
Jan 31, 2016
1,901
3,377
Hymer B544 (2012)
newbie
Sorry, my electrical experience is quite low, I have no idea what you just posted LOL
Lenny HB
53,417
149,915
Hymer B678 DL
A shunt is basically a very low value high power resistor which is connected to the negitive side of the battery and the load (connection that normally goes to the battery) is connected to the other end. When current passes through the shunt the volt drop across the shunt is measured and converted to amps by the meter.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I bought one of those, but I bought the right one with a shunt to measure DC current. Only came last week so not tried it yet. Looks a nice piece of kit. It was cheaper than yours too.
Lenny HB
53,417
149,915
Hymer B678 DL
You have 100 amp meter so a 100 shunt would be better also I would buy from the same supplier as the meter.
Your meter may have a shunt built in but I don't think so terminals are only low current.
Talk to your supplier, when I had a query with Chinese supplier for the meter I bought they were very helpful.
Jan 19, 2014
9,385
24,754
Derbyshire
Elddis Accordo 105
since 2014
Doesn't look very good quality. Wonder how long these Chinese monitors work for (n) Ask your supplier for a NASA BM1 battery monitor. Problem sorted :cool:
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The meter you have doesn't have any facility for use of a shunt (according to the diagram on the unit). It will however only measure up to 20A and may not be suitable for your needs.
Apr 27, 2016
6,872
7,991
Manchester
A class Hymer
Since the 80s
The picture in @tonyidle's post shows a 20 amp meter. The terminals look just about capable of taking 20 amps. The OP's device is a 100 amp meter. I haven't seen the terminals but it must surely be capable of handling 100 amps.
The idea is, the main current goes through the load terminals, which go to a 100 amp built-in shunt. The power for the display and logic circuits comes from the DC IN, which connect separately to the battery positive and negative.
I haven't seen the installation instructions, but I would imagine the load connections can be on either the positive or negative side of the battery. The most usual is on the negative side, but in Elektrobloks the internal shunt is on the positive side.
Apr 27, 2016
6,872
7,991
Manchester
A class Hymer
Since the 80s
If I'm right, none of the pictures shows your device correctly. Can you post a picture of the reverse side of your device?
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
Is this your 100A device?
Apr 27, 2016
6,872
7,991
Manchester
A class Hymer
Since the 80s
So it looks like you need an external shunt for a 100 amp meter. The shunt is the element that senses the current flow, so basically you place it at the point where you want to measure the current flow in amps.
It will require heavy duty wiring and good solid connections on the terminals that carry the full current to be measured. It's best to choose the shunt location to minimise the extra heavy duty wire required. Right next to the battery negative is a popular place for it.
The two thin 'sense' wires from the shunt to the meter do not need to be especially thick, because they are carrying the voltage signal, not the main current.
The two supply wires from the battery terminals to the meter also do not have to be especially thick, because they are just carrying the small current required to power the meter circuitry and backlight.
The 100 amp shunt shown in @hilldweller's link is precisely calibrated to give exactly 75 millivolts when carrying 100 amps. That's what your meter is expecting. That's why you have to buy the right shunt to go with the meter, probably from the same supplier.
BusyBuilder
Jan 31, 2016
1,901
3,377
Hymer B544 (2012)
newbie
Thanks all, I have ordered a new meter and shunt as above.
