Solar Controller (1 Viewer)
Daifuse
183
310
Milford Haven
c class
Since 2011
I fitted a 100W Biard solar panel earlier in the year. It feeds 2 x 110Ah. batteries. The charge rate is not indicated on the controller except by tri-colour led's and I'm concerned that the batteries are being over-charged - loss of electrolyte in both and higher than normal voltage - 14.9v in sunlight. I'd prefer a better controller so that I can see what's going on. Anyone have any suggestions?
19,346
30,232
I use a Votronic MPPT controller and then a Votronic solar computer that simply plus into the controller. There is no information on the controller other than a few lights.
The solar computer gives charge in amps, battery volts, total ah delivered since a reset and total power in KWh again resettable so you can have a weekend away and see what power you have had from the sun.
Not the cheapest by a chunk but works for me.
Jan 22, 2013
1,253
60,243
London SE
A class Adria vision I707
since 1971
I have just fitted a second one of these MPPT controllers, again no cheap but very good quality,
It returns about 6 amps from a 100 W panel from a overcast sky today
So well satisfied,
Jan 22, 2013
1,253
60,243
London SE
since 1971
I have both the 200w and 300w controllers running two different leisure battery banks, they both perform exceptionally well even in poor light,
Recommended buy IMO:thumb:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i have been using a couple of these Broken Link Removed
dont really give lots of info. but have a digital volt gauge built in to the inverter so i now can just see if the volts are holding or dropping . been working fine for years .
i think its so easy to get too complicated .
Daifuse
Daifuse
183
310
Milford Haven
c class
Since 2011
Thanks for the suggestions - the consensus seems to be MPPT - I'll give it a try but it looks as if both my batteries are cooked. More expense!
43,329
49,444
as your batteries are goosed i would suggest the solar controller is trying to push more power in to compensate for the poor battery condition, which is why its showing 14.9v.
New batteries should bring it back to 13.6v to 14.7v depending on battery charge state.
Fit a NASA BM1 and see The Big Picture. All in and out.
My solar controller is odd, it runs up to 14.6V for a second then drops to 13.6V for a few seconds then back up to 14.6V. Does not appear to be harming the battery.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Absolutely correct. A battery with a faulty cell, (they usually drop one of the outside cells first,) will constantly be asking for more voltage. In theory, a 12volt battery should be able to accept 15.5 volts before 'gassing', and therefore losing electrolyte, but in practice, this voltage can be much lower, depending on atmospheric conditions, ambient heat, temperature etc.
