I posted earlier than my leisure batteries are dead, and only 3 years old.
I currently have an EP solar dual battery control and a battery master but I still managed to flatted engine battery and both LFD90 leisure batteries
Appreciate van not been used for 5 months.
Engine battery seems to have recovered atm.
My concern is the solar charge may not be operating correctly and may need replacing. I am not adverse to replacing it.
Ive read before that Votronic MPP 350 are recommend units. Also read that MPP is better than PWM which is my current unit.
I see there is also 165 and 250 model. Assume difference is
350 up to 350w
250 up to 250w
165 up to 165w
I only have 1 panel which is 150w
Would the 165 be okay or is it better to get an high capacity unit?
Are they easy to replace, IE Is it just plug and play with existing wiring or would I need an expert to re wire it?
Do you feel its worth changing and the charger is prob the issue so best to replace or could I have other issues?
Thanks in advance
350 up to 350w
250 up to 250w
165 up to 165w
Thanks in advance
